Thread: GP 2008 built in car alarm question
Results 1 to 11 of 11
  1. #1 GP 2008 built in car alarm question
    Mar 2013
    Canada
    I was wondering shouldn't the built in car alarm ring if I open the door from the inside? Example I rolled down the window and arm the car, I then reach in and open the door from the inside as to mimic a force entry, doing this the alarm didn't ring. I was under the impression is should.
    Sent from my SGH-I337M using Tapatalk
  2. #2 Re: GP 2008 built in car alarm question
    GXP Level Member
    Mar 2015
    Tomball
    Try opening the door then closing the door, press the lock button 2 times then pull the lock up by hand and open the door. If that doesn't work get out of the car and do the same thing with the window down.
    Jeff
  3. #3 Re: GP 2008 built in car alarm question
    Mar 2013
    Canada
    Negative, press the lock button twice pull the lock by hand and opened the door and nothing, repeated the same process from the outside when the window was down and it didn't ring.
  4. #4 Re: GP 2008 built in car alarm question
    GXP Level Member
    Mar 2015
    Tomball
    Ring? The horn goes off on my 05', there are some settings in the DIC for locking, unlocking and whether or not the key will disarm the system. I am not sure about 08' but it should work the same as far as arming it and then opening the door.
    Jeff
  5. #5 Re: GP 2008 built in car alarm question
    Mar 2013
    Canada
    I mean the horn didn't sound, so it's some setting that needs to be turned on?
  6. #6 Re: GP 2008 built in car alarm question
    GXP Level Member
    Mar 2015
    Tomball
    I am not sure on the 08' but there are settings in the DIC (Drivers Information Center), it's the deal in the middle with the 3 or 5 buttons on it. It has the mileage, and trip odo on it. My car has a 3 button one and there are settings in there for the security system.
  7. #7 Re: GP 2008 built in car alarm question
    Mar 2013
    Canada
    I found the settings on the DIC and the anti theft is turned on. Quick question do you have the option where you can disarm the alarm if it sounds by inserting the key in the driver key cylinder? This option from the manual
    KEY CYLINDER DISARM: If the vehicle has a content
    theft-deterrent system, and ON was selected on the
    THEFT DETERRENT screen, this screen allows
    this feature to be turned OFF or ON. This feature
    determines whether the driver’s door key cylinder may
    be used to disarm the content theft-deterrent system.
    If OFF is selected, the vehicle’s content theft-deterrent
    system can not be disarmed by unlocking the driver’s
    door using the driver’s door key cylinder. Selecting OFF
    prevents a thief from disarming the vehicle’s content
    theft-deterrent system by attacking the driver’s door key
    cylinder, and may make the vehicle more secure.
    However, if OFF is selected, unlocking an armed vehicle
    by using the driver’s door key cylinder and opening
    the door will cause the content theft alarm to activate.
    For this reason, it is recommended that the vehicle
    be unlocked using the remote keyless entry system
    when this feature is set to OFF.
    If ON is selected, the vehicle’s content theft-deterrent
    system can be disarmed by unlocking the driver’s
    To program this mode:
    1. Press the set/reset button to scroll to OFF or ON.
    2. Press the options button again to advance to
    the next screen.
  8. #8 Re: GP 2008 built in car alarm question
    GXP Level Member
    Mar 2015
    Tomball
    Yes that is one of the options on my car. I didn't get a manual with my car so I have just scrolled through the menus. Does the radio shut off when you open the door? I am wondering if the latch switch is working.
    Jeff
  9. #9 Re: GP 2008 built in car alarm question
    Mar 2013
    Canada
    Yes it does shut off, I think I am not waiting long enough for the alarm to fully arm
  10. #10 Re: GP 2008 built in car alarm question
    GXP Level Member
    Mar 2015
    Tomball
    Maybe so I haven't tried mine immediately after arming. Most of the time I walk up to the car forgetting its armed and the door lock works when it wants to and it goes off when I open the door.
    Jeff
  11. #11 Re: GP 2008 built in car alarm question
    Mar 2013
    Canada
    Gave it another try,i disabled the whole system and enabled it back on. Locked the doors and opened it from the inside and the alarm went off. Thank you for everything
  1. 1999 GP Security Alarm Question
    By bcampy in forum General Grand Prix Discussion
    Last Post: 02-20-2015, 03:34 PM
  2. Alarm going off inside car when reaching highway speeds..coolant temp alarm?
    By MattTheBaker123 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2012, 09:39 AM
  3. Built Engine - Built Trans = This
    By LowRidinCrew in forum Off Topic Discussion
    Last Post: 07-28-2012, 01:38 AM
  4. 2000 GTP factory alarm question
    By ls6velless454 in forum Audio, Security & Visual Electronics
    Last Post: 05-19-2010, 09:31 AM
