Thread: Oil leak
Results 1 to 12 of 12
  1. #1 Oil leak
    Nov 2008
    Indiana
    Im noticing an oil leak on my 02 GTP. I pressure washed the engine and best I can tell its coming down around the crank pulley area. Ive read the 3.8 engines usually don't have a issue with the crank seal leaking.. if not that then what else could it be. Its so tight in there its hard to tell where its coming from. I checked the oil sender and it looks dry. Here is a pic.. ( looks like I need a new motor mount as well )
    2002 Grand Prix GTP
  2. #2 Re: Oil leak
    Jun 2015
    Clearwater, FL
    I'd say to give it another good washing and re-check, there's still a bunch of gunk on your subframe and oil pan from what I can see. I'd guess it could be coming down from the valve covers, or its the front main or oil pan
  3. #3 Re: Oil leak
    looks like its the oil pan judging by the oil drips on the pan bolts on both sides of the pan.
    if it was the crank you would clearly see it leaking from behind the balancer.
    put the car on ramps, or jack stands get some degreaser and soak the bottom of the engine down, then power was it all best you can again.
    then watch for stuff to get wet again. clean that motor mount and the bucket its sits in. oil leaks kill the engine mount.
    also take a paper towel folded up to a square and wipe under the rear valve cover lip, if it comes back wet with oil the covers leaking. do the same for the front. do this on a cold engine. you can get a nice burn if not careful.
  4. #4 Re: Oil leak
    Nov 2008
    Indiana
    Thanks.. Ill give it another good clean up and post pics again
  5. #5 Re: Oil leak
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    That pulley looks good. New?
  6. #6 Re: Oil leak
    who can tell. it looks like the engine is running.
  7. #7 Re: Oil leak
    Nov 2008
    Indiana
    yeah the engine was running when I took the pic
    2002 Grand Prix GTP
  8. #8 Re: Oil leak
    mine was a drip a second. so i made a trough to catch the oil drip so it didnt hit the mount any more while i was trying to fix, then let it run. once it warmed up it leaked.
  9. #9 Re: Oil leak
    Nov 2008
    Indiana
    Goober... Excellent idea. I guess it was the crank seal ? Was it hard to change ?
  10. #10 Re: Oil leak
    it was a new seal. i had just dropped that engine in and the seal broke, and i had a deep groove in the balancer. it needed a repair sleeve and another seal.
    seal swaps not to bad, i took a screw driver to the lip and hammered it under, then pry it out.
    getting the new one in i used 2 hammers, one was wood handled so i used the butt end on the seal edge while holding it firmly with the one hand, then tapped it in with the other hammer hitting the top of the wood hammer. a block of wood would work too.
    the balancer, you need the right bolts for the puller, they are not in the puller kits.
    http://www.grandprixforums.net/threa...a-crank-sensor the bolts you need are listed here. iirc i used 56 or 58 mm long bolts. worked just fine, puts the puller a 1/4 inch off the balancer, and you need that little bit of extra room.
    air gun is king for this job, but can be done with hand tools.
  11. #11 Re: Oil leak
    Nov 2008
    Indiana
    cool.. thanks.. I went through the the bolt thing for the puller. I went to AZ and rented the puller and found out they didn't have the correct bolts, went to hardware store and got them so I keep them in my tool box. I had to replace the crank sensor on my wifes 04 Bonne, I was just wondering how bad it was to pull the seal as well.
    2002 Grand Prix GTP
  12. #12 Re: Oil leak
    its not to bad.
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
