Thread: Oil leak
Results 1 to 12 of 12
Threaded View
  1. #1 Oil leak
    Nov 2008
    Indiana
    Im noticing an oil leak on my 02 GTP. I pressure washed the engine and best I can tell its coming down around the crank pulley area. Ive read the 3.8 engines usually don't have a issue with the crank seal leaking.. if not that then what else could it be. Its so tight in there its hard to tell where its coming from. I checked the oil sender and it looks dry. Here is a pic.. ( looks like I need a new motor mount as well )
    2002 Grand Prix GTP
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
