Thread: Ignition Switch won't turn 97 GTP
Results 1 to 4 of 4
  1. #1 Ignition Switch won't turn 97 GTP
    Apr 2011
    Lilburn, GA
    I have a key that fits the doors and glove box, but will not turn to the on or start position when it is in the ignition. I have read several threads regarding ignition switch issues. I have tried lube, still nothing. I am thinking of having a dealer cut a key from the VIN, as the key is pretty worn. Before I do that, I wanted see if any of you had any input on this issue. My 98 key turns very easily and does not require any push in of the key or collar, that is missing on the 97. Could the key just be that worn?
    Rick Thomason
    GTPMayhem
    Ignition Switch won't turn 97 GTP Attached Images
  2. #2 Re: Ignition Switch won't turn 97 GTP
    SWPA
    Is the steering wheel locked? If so, grab the wheel tug on it while you try to turn the key.
  3. #3 Re: Ignition Switch won't turn 97 GTP
    Apr 2011
    Lilburn, GA
    Steering wheel is locked; and no, this did not work. Can the lock cylinder be replaced without the key being able to turn?
  4. #4 Re: Ignition Switch won't turn 97 GTP
    Feb 2013
    37.295091, -121.930053
    uhhh yeah it can. also if memory serves me there is a lock on the bottom that needs to be pressed to release the key
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  1. Ignition Issue? Turn Key = Nothing
    By Gratefuldiver in forum General Tech Discussion
    Last Post: 07-27-2015, 05:14 PM
  2. Ignition key, won't turn to off position
    By buck in forum General Tech Discussion
    Last Post: 01-11-2012, 12:29 PM
  3. Ignition will not turn to start position
    By glovey in forum General Tech Discussion
    Last Post: 08-08-2011, 03:51 PM
  4. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
  5. HELP! Ignition key will not turn in 1994 SE
    By cerdman in forum General Tech Discussion
    Last Post: 08-10-2009, 12:09 AM
