Thread: AC Gurus needed...
Results 1 to 20 of 23
  1. #1 AC Gurus needed...
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    Hey guys, I'm trying to get the AC running in my 04 Grand Prix. The system was empty when I swapped the motor 2 years ago, and I never bothered to do anything with it. I recently replaced all of the seals and o-rings in the system, and was wondering what else I should swap out before attempting to get it filled.
    Thanks
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  2. #2 Re: AC Gurus needed...
    if your taking it to a shop they will put the system under vacuum to make sure its not leaking, then they will fill it.
    you change the orifice tube? if your old compressor took a crap its best to change that tube too.
  3. #3 Re: AC Gurus needed...
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    If the system has been opened, it needs to be put under vacuum for "X" amount of time. They can also do a leak test, but it only finds large leaks.
    Like scotty said, replace the orfice tube, and possibly the accumulator.
    When it gets refilled, add a small amount of UV Dye to the system just for safe measures incase there is a leak or one springs up.
  4. #4 Re: AC Gurus needed...
    Pennsylvania, USA
    The accumulator should really be replaced since it contains a desiccant bag that absorbs any moisture left over after pulling a vacuum on the system. Having been non-functional for that long, the bag has probably had its useful life used up at this point.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  5. #5 Re: AC Gurus needed...
    Jun 2015
    Clearwater, FL
    Additionally, might not be a bad idea to clean the condenser really well. I just use some simple green and a garden hose. Let it soak for like 10 mins, rinse it off. If the condenser gets clogged with road grime and debris, it will inhibit the heat transfer.
  6. #6 Re: AC Gurus needed...
    GXP Level Member
    Mar 2015
    Tomball
    Did you open the system for any length of time, or did you drop the compressor and remove the engine with the system intact? If it was open at any time and was exposed to anything like actually driving the car or just being open for a few weeks then I would flush the entire system out to get any debris out and as stated above the Accumulator and the Orifice tube, and the dye is a great idea any time I put freon in for someone I always use the some dye. You don't even have to use any of that expensive black light stuff, just use a CFL black light bulb from Walmart in a drop light and it will light up like you slaughtered a Predator in there if it does leak.
    Jeff
  7. #7 Re: AC Gurus needed...
    Buffalo
    Automotive r134a had dye in it.....
  8. #8 Re: AC Gurus needed...
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by RickyBobby03 View Post
    You mean all? Because I know there are a lot that do not. Dupont Suva doesn't and most of the other store brands don't. I always add dye first then run a can of regular 134A through my gauge set just so I don't get the dye everywhere.
    Jeff
  9. #9 Re: AC Gurus needed...
    Buffalo
    My supplier only carried automotive for a while. When we needed it for smaller appliances , we had just the standard r134 no dye
    Check the size of the nozzles on each tank
  10. #10 Re: AC Gurus needed...
    Enfield, CT
    X3 on the accumulator and orfice tube. Rock auto has the Delphi accumulator for about $15 and an ac delco orfice tube for about $3 I think.
    Sent from my LG G3
  11. #11 Re: AC Gurus needed...
    GXP Level Member
    Mar 2015
    Tomball
    Oh, you are talking about the larger tanks of 134 not the cans at the store right?
  12. #12 Re: AC Gurus needed...
    Buffalo
    Ah yes. The smaller cans - no idea. It should have dye in it if it's automotive. At least thats how it is for me in what I do
  13. #13 Re: AC Gurus needed...
    GXP Level Member
    Mar 2015
    Tomball
    Unless it is marked on the can they usually do not have dye in them. They have regular cans, cans with "stop leak" in them cans with dye (they are usually purple) cans with PAG in them. Then you can buy just the oil as well. I did one last week for a guy and told him to buy a can with dye in it and then told him not to leave it in his car. He did and came out now he has dye all over the inside of one of he seats. Then next day he brought in another can and I filled it and ended up needing more I have about 4 cans here and used one. Man that dye sucks to get out.
    OP make sure to get the correct amount of oil, I don't remember how much you are supposed to use on an accumulator change out but it's around an ounce or so. Also if your having it professionally done they should know.
    Jeff
  14. #14 Re: AC Gurus needed...
    Buffalo
    When replacing the compressor , the instructions to measure the oil are included
    you need to drain both new and old compressor , compare and adjust
  15. #15 Re: AC Gurus needed...
    GXP Level Member
    Mar 2015
    Tomball
    He didn't say anything about changing the compressor and the last 2 accumulators didn't have instructions on how much oil is supposed to be replaced when changing them I had to look it up.
    Although sitting for the last 2 years probably is going to require a compressor change especially a system with a leak, at least on this side of the country.
    Jeff
  16. #16 Re: AC Gurus needed...
    Buffalo
    Just measure what you remove and replace I did all new Delphi compressor , ac delco accumulator and orifice tube off rock auto for $200
  17. #17 Re: AC Gurus needed...
    Oct 2012
    Pinckney, MI
    Thanks guys!
    I looked on RockAuto and don't see an orifice tube listed (2004 Grand Prix). Was this part used in the 04+ cars?
    Looks like the A/C Receiver Drier / Accumulator is $29.99 for ACDelco, so I have one of those on order.
    I honestly can't remember if I opened the system in order to swap the motor around. I do know that I initially pulled the compressor from the motor, and left it in the engine bay sealed up when I pulled the motor out. I may have had to empty it at some other point, I can't really remember. The system has been closed for the most part though, never driven with anything disconnected.
    Is the only good way to find a leak to fill the system and see if it loses pressure?
    Thank you
    -Rob
  18. #18 Re: AC Gurus needed...
    Buffalo
    Fill it with nitrogen. Listen and / or spray for a leak.
    Chances are it's leaking at the service ports or condensor
    You could pull a vacuum but it's not going to tell you where the leak is.
    If you fill it , you may be able to see the dye or oil or hear it. You can also spray too
  19. #19 Re: AC Gurus needed...
    Oct 2012
    Pinckney, MI
    Looks like this system uses an Expansion Valve in place of the Orifice Tube. Parts ordered!
    I'll probably be taking the car into a shop for a vacuum test / AC charge. Hopefully there are no leaks, and I can get some cold air!
    -Rob
  20. #20 Re: AC Gurus needed...
    Enfield, CT
    I did the same exact thing except got a new Delphi accumulator. $192. Sweet deal and worked great for a month until the car was totaled lol.
    Sent from my LG G3
  1. Alternator Gurus...
    By Booba5185 in forum General Tech Discussion
    Last Post: 02-21-2015, 06:31 PM
  2. PC Gurus - Issue with explorer.exe
    By FoSHO99 in forum Off Topic Discussion
    Last Post: 04-04-2012, 10:37 PM
  3. Any computer gurus out there???
    By Iron Indian in forum Off Topic Discussion
    Last Post: 07-31-2009, 09:30 AM
  4. Electrical Gurus step in (relays)
    By Toofastgs in forum Audio, Security & Visual Electronics
    Last Post: 03-11-2009, 10:30 AM
  5. Any wiring gurus
    By archemedes in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2008, 06:00 PM
