I have 02 gtp I have done everything possible to fix this car: injector, oem plugs, oem wires, lim gasket, computer, coil, icm, leak down test, #4 cylinder 130 psi, the rest closer to 150. The dealership told me it is because of the lower compression. They said they checked wiring everything ok. They also said leak down test was ok. How can leak down test be ok but not compression? Car misfires under 1600 rpm over that no misfire. Snap on scanner confirms that. I am in this car 1200$ don't want to go any more from assumptions. Any advice would help thanks folks
