can you get a stock pcm tuned ? where can you get a tune ? dealership or repair shop?
i was wanting to check for kr before modding 99 gtp 135000 miles pretty sure it was babied for first 100000 miles worried about carbon build up
Yes, Visit Getoverkilled.ca. Will does great mail order tunes. You can always hope someone local is close enough to help you out but that's a crapshoot and will is pretty well respected on here. Dealerships or repair shops no, but a performance shop would.
Get you a bafx obd2 bluetooth adapter and download the torque app. It'll let you scan for KR and a bunch of other stuff.
Seafoam for carbon build up, or run some e85 with a full tank it's available and it'll clear it up.
Good luck!
Edit: just noticied Will's site is down, not sure what the deal is. He still does great tunes and is a member here so hopefully if you're interested, you can get in touch with him. Besides Will, Reptile is a admin here and i've heard good things about him too.
well i got the obd2 and the torque pro i dont see anything about timing or kr looked up a few utube videos but im pretty sure they are car by car or ecu by ecu because i didnt have all the options they showed on video. what i watched was on a newer car i think guess ill go check my 0-60 time hope that works!!
you have to load GM pid's. then KR will show up with all the other live data. once set up when you "add" a gauge, do it in the car, this way anything that green is active and you know will work.
this guys got simple directions http://www.grandprixforums.net/threa...ive-KR-monitor
you dont need the t scan iirc but its got more stuff too and its free.
thanks for the info i will be checking it out btw 0-60 works. best i had was 7.0 best 1/4 was 15.2 thought it would do better
