Optima® 8004-003 RedTop® Starting AGM Battery 34/78
Part Number: 8004-003
Manufacturer: Optima
Description: OPTIMA® REDTOP® 34/78 Ultra high-performance SPIRALCELL TECHNOLOGY® AGM (absorbent glass mat) battery with reliable cranking power for your auto, car or truck and twice the life. The OPTIMA® REDTOP® will outperform and outlast traditional batteries in demanding cranking/starting applications. The ultimate high-CCA starting battery for vehicles that have alternators capable of keeping up with all electrical loads. If you have demanding electrical accessory loads such as winches, audio systems, and other devices, take a look at the YELLOWTOP® product line. The OPTIMA® model number for this battery is 34/78. If you are replacing an OPTIMA® battery you already have, this model is the same as batteries marked 8004-003, 9004-003, 27990, 34-78, 34/78-980, RED34/78, SC34U, or N9934/78RED. Includes applicable installation and/or height adapters for this battery.
Features:
  • Strongest five-second starting burst
  • Up to two times longer life
  • More than 15 times the vibration resistance
  • Completely spillproof, mountable in virtually any position
  • Maintenance-free
  • Faster recharging
  • Optimal starting power
  • Cold Cranking Amps: 800
  • Cranking Amps: 1000
  • Nominal Voltage: 12 volts
  • Weight: 38.8 lbs
  • Length: 10.06"
  • Width: 6.94"
  • Height: 7.88"
