Thread: Aerdoforce gauge
Results 1 to 15 of 15
  1. #1 Aerdoforce gauge
    Feb 2015
    california
    I just gor an Aeroforce gauge and am wanting to know all the standard readings for each scan or sensor that is being read. Is there a write up for this or a list of what would be the standard readings for each?
  2. #2 Re: Aerdoforce gauge
    Kemmerer, Wyoming
    There is a write up someplace, but I don't remember where. Are there any specific ones you want to know about
  3. #3 Re: Aerdoforce gauge
    Feb 2015
    california
    Just really wanting to know all.
  4. #4 Re: Aerdoforce gauge
    Feb 2015
    california
    Quote Originally Posted by SgtMarshal View Post
    I guess specifically what is the iat expected? and does the gauge read transmission temp? What should It read? What's the main parameters to be looking at?
  5. #5 Re: Aerdoforce gauge
    I posted an expected readings thread. Search on me and hopefully you can find it.
    IAT will vary with outside temp and how long you are sitting still etc.
  6. #6 Re: Aerdoforce gauge
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by silenthaven View Post
    Yes.
    Whatever your trans temp is; 0-250*.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: Aerdoforce gauge
    Feb 2015
    california
    Is there good or bad temp?
  8. #8 Re: Aerdoforce gauge
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  9. #9 Re: Aerdoforce gauge
    Feb 2015
    california
    You didn't talk about knock retard?
  10. #10 Re: Aerdoforce gauge
    Jul 2010
    Coquitlam,BC,Canada
    Had to re-read that.....thought you were calling Bill a retard. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #11 Re: Aerdoforce gauge
    Feb 2015
    california
    My aeroforce was working but after accelerating it turned off and only the two red led lights blink ever time after ppowering on. What's going on?
  12. #12 Re: Aerdoforce gauge
    Did you wire it in correctly??
    You will want to provide a 12v power source directly to the scangauge at all times. Remove the red jumper from the back of the gauge, use the 3 wire harness and provide a 12v power source. A add a circut dealio to the glove box from a radio or ign fuse work great or anything else that is a 10amp circut that runs when the key is on.
  13. #13 Re: Aerdoforce gauge
    Feb 2015
    california
    I have the OBD2 connected to gauge and then red power wire connected to an ignition wired to same power source as stereo. White nd green wires are unused
  14. #14 Re: Aerdoforce gauge
    Houston
    Check the back of the gauge and make sure the 12v harness didn't vibrate loose
  15. #15 Re: Aerdoforce gauge
    Feb 2015
    california
    I need to know the accurate values or expected readings for the following parameters. Answer as many as you can please and if you can explain their importance. Im wanting to figure out which 8 to cycle thanks.
    Mods: 3.5 pulley 3" catted downpipe MSD wires NGK plugs 180 tstat K&N intake zzp Power log borla cat back
    Trans Temp
    MAF SENSOR LB/M
    MAF FREQUENCY
    FUEL %
    IGNITION ADVANCE
    PULSE WIDTH
    SHORT TRIM B1
    SHORT TRIM B2
    LONG TRIM B1
    LONG TRIM B2
    O2 B1
    O2 B2
    IAC
    ENGINE LOAD
    TORQUE CONVERTER SLIP
    TORQUE CONVERTER STATUS
