Quote Originally Posted by ScottyDoggs View Post
it does. and thats the most its worth doing. then headers.
did you pass smog with that dp, or you swap it back to the stock one for inspection?
just smogged it and then had it installed after. In 2017 i may try smogging it with it on since i have a borla exhaust maybe they wont question it? It seemed pretty relaxed as long as the zzp cat passes the sniffer. if not ill have to swap. I tried installing the dp myself but no dice. The manifold bolts were hard to reach and get a good torque on. But maybe that was cause they were stock bolts?
