Thread: Need help on diagnosing problem on 97 grand prix gt 3.8L
Results 1 to 4 of 4
  1. #1 Need help on diagnosing problem on 97 grand prix gt 3.8L
    Jun 2015
    muskegon
    Okay so... it all started one day when my gas light came on, i was trying to make it to the gas station when my car just stalled so i figured i ran out of gas. A cop brought me into the gas station where i got $5 worth of gas. Came back and put the gas in. Went to start it and nothing happened. Mind you i was already late for work so i was stressed when the car didnt start.
    Later that night, my co worker brought me to the gas station where i got $5 more worth of gas. Car still wouldnt start. Frustrated, i called a friend of mine who towed me home and he told me the pump wasnt kicking on. So the pump must be bad, so we thought...Before we changed the pump, my uncle told me to check the relay. We replaced the relay and still nothing. Fuse is good. We changed spark plugs, crank and cam sensor, even went as far as changing the ecm. Still nothing. The fuel pump will run when bypassed through the relay, but why wont it run when the key is turned to the "on" position? I'm so lost. And i dont have money to keep shoving into it. Is this a common issue? What should i do?
  2. #2 Re: Need help on diagnosing problem on 97 grand prix gt 3.8L
    Maybe the fuel pump resistor.
    Is this motor supercharged?? Because on those you could just bend the a tab on a relay to put the pump in high speed mode and bypass the resistor.
  3. #3 Re: Need help on diagnosing problem on 97 grand prix gt 3.8L
    Fuel pump resistor would allow it to start and then it would stall.
    If your pcm is telling the FP not to turn on.. that would do it. Now.. reasons why that might happen could be a bad maf most likely. Unplug the maf and see if it'll start.
  4. #4 Re: Need help on diagnosing problem on 97 grand prix gt 3.8L
    Mar 2015
    mn
    check for spark, if not pull the ingnition control module and have it tested at your local auto part store
  1. 99 Grand Prix GTP problem
    By jtckf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2014, 12:23 PM
  2. Grand prix problem
    By lorrodriguez in forum Introductions/Noob Questions
    Last Post: 11-22-2012, 12:07 PM
  3. Problem with my Grand Prix
    By the jagaloon in forum Off Topic Discussion
    Last Post: 06-02-2010, 08:55 PM
  4. Need Help diagnosing tranny problem.
    By trbsht in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-05-2009, 12:33 PM
  5. 01 Grand Prix problem
    By neumjo in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-05-2008, 05:36 AM
