Thread: 2 codes
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
  1. #1 2 codes
    MINNESOTA
    This are the codes I am getting
    P0420
    and P1107
    I replaced my Headers about 2 months ago
    I have been smelling exhaust fumes inside the car
    What could be causing that
    Thanks
  2. #2 Re: 2 codes
    420 is a cat code. what year is you car? over a 01 you'll get that with headers.
    this one https://www.google.com/search?q=P110...m=122&ie=UTF-8 is your map sensor. check its plugged in or the wires are not damaged.
  3. #3 Re: 2 codes
    MINNESOTA
    My car is a 2005
    I don't think a cat came with the new headers
    Do I have to put the old cat on
  4. #4 Re: 2 codes
    for you 04 up guys if you cant find a tuner to remove the code its best to just install a real cat, you old one is not large enough, its like 2.5 it will just be a choke point if you re use it.
  5. #5 Re: 2 codes
    and we got this on the rear o2 sensor for the 01 up guys. http://www.grandprixforums.net/threa...ou-should-know
  6. #6 Re: 2 codes
    MINNESOTA
    Tuner?
    Is it easy to use?
    About putting another cat, what is the correct diameter that I need to get
  7. #7 Re: 2 codes
    3 inch in and out. you dont want a high flow cat. you want a real cat. well need one really. the code is the rear o2 reporting cat inefficiency. aka its missing.
  8. #8 Re: 2 codes
    MINNESOTA
    Thanks
    Now to look for cat
    Do you think I can find one on ebay?
  9. #9 Re: 2 codes
    You want a serious quality cat to ensure it's happy. A cheap high flow will not make the pcm happy.
  10. #10 Re: 2 codes
    Quote Originally Posted by valente View Post
    Thanks
    Now to look for cat
    you should, look for a 3 inch universal cat. make sure its not hi flow. hi flow cats are cheap, like 50 bucks. your gonna pay a bit more for a real cat.
    if you cant find one on e bay, hit your local muffler shop and ask them for a price to install one.
  11. #11 Re: 2 codes
    MINNESOTA
    Thanks
    Any suggestions on where I can purchase one
  12. #12 Re: 2 codes
    you local muffler shop has them or can get them, its best to get it welded in too.
  13. #13 Re: 2 codes
    MINNESOTA
    I can weld it myself, no problem there
    Just going to have to find one
    Thanks
  14. #14 Re: 2 codes
    time to search the net. look for a universal 3 inch cat. amazon and ebay should net some results.
  15. #15 Re: 2 codes
    MINNESOTA
    I found some on ebay
    Magnaflow some oval some round, does it matter on the one I get
  16. #16 Re: 2 codes
    round fits good. oval double check the dimensions and make sure it will fit the tunnel under the car.
  17. #17 Re: 2 codes
    not sure if you saw the chat, bill says that magnaflow cat is no good for you lol
  18. #18 Re: 2 codes
    MINNESOTA
    Meaning its cheap
  19. #19 Re: 2 codes
    its likely hi flow, just cost more due to the name on it.
  20. #20 Re: 2 codes
    MINNESOTA
    Cost more?
    Your saying that I can find a cheaper one
  1. 04 gtp with two codes need help
    By justin10morrissey in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2013, 09:13 PM
  2. 4 Codes - PCM?
    By noreasonwhyy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-10-2013, 09:45 AM
  3. got some codes need help
    By buschegt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2012, 06:20 AM
  4. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  5. PID Codes?
    By BwolfGT in forum Off Topic Discussion
    Last Post: 10-20-2010, 07:41 PM
