Thread: Leaking power steering fluid.
Results 1 to 4 of 4
  1. #1 Leaking power steering fluid.
    SE Level Member Drive XR7's Avatar
    Cleveland, OH
    Took a trip and found the power steering pump was making all kinds of noise. I filled it up with some of the leak stop steering fluid, and found a puddle under the passenger side of the front end the very next day.
    I haven't taken it all apart yet, but from what I've read, could be the pump or the rack, and its not too bad to do the work in my garage.
    What have others experienced? All these things are breaking all at once on my GP. Its frustrating.
    Jason
    2001 Bronzemist Pontiac Grand Prix GTP - SOLD!
    2003 Sonic Blue SVT Mustang Cobra Convertible #2421 (1 of 340)
    2013 Ruby Red Ford Edge Limited EcoBoost
  2. #2 Re: Leaking power steering fluid.
    you need to jack the car up run it, then look for th eleak, then replace that part. could be the pump, a line, or the rack.
    rack leaks out the dust boots when bad.
  3. #3 Re: Leaking power steering fluid.
    St. Louis
    Quote Originally Posted by Drive XR7 View Post
    Sounds about right for a 14 yr. old W-body to me. If you're lucky it's the pump or the return line (low pressure rubber line). If not, then it's time for a rack most likely. I nursed my old rack along with some Lucas PS additive for almost 2 years before it almost locked mid-turn one day. Luckily these cars aren't too hard to find parts for yet at reasonable prices and there are also many other years/cars that could work.
  4. #4 Re: Leaking power steering fluid.
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    I know those feels
  1. Replies: 9
    Last Post: 07-22-2014, 11:01 PM
  2. power steering fluid
    By tstaller2005 in forum General Tech Discussion
    Last Post: 05-03-2011, 10:34 AM
  3. Power Steering Fluid
    By Vlad0691 in forum General Tech Discussion
    Last Post: 11-12-2010, 08:48 PM
  4. Power Steering Fluid
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-22-2010, 01:26 AM
  5. What power steering fluid is best?
    By dl1027 in forum General Tech Discussion
    Last Post: 05-09-2010, 07:55 PM
