Thread: Water in floorboard V.123.23423454.4543 *Update*
Results 1 to 2 of 2
Threaded View
  1. #1 Water in floorboard V.123.23423454.4543 *Update*
    GTX Level Member real diehl's Avatar
    Salina, KS
    We got about 4 inches of rain the other night, and some more last night. Saturday night, my car accumulated about 3 inches of water in the passenger side floorboard, the driver's side floor was damp as well.
    Sooo, I took out the entire interior. I removed the carpet, and I thought my problems were leaking rubber door weather stripping because of how the water looked like it dripped in by the door. With all the carpet out, I sprayed the sunroof and doors and watched where it came in. The sunroof doesn't leak at all. The problem was the window seal, on the outside. There's a gap in the very front of the window seal, about the size of a small nail head. The water comes in through that seal, and hits a speaker deflector, (inside the door), and apparently comes out of the bottom of the door panel right below the speaker.
    Has anybody had this problem? I know it's not the sunroof, and I've replaced the $3 cowl piece. From the factory, water comes in the door, and that's not a problem because there are drain holes in the door, but not all the water is making it to these drain holes.
    *EDIT*- Update
    Found where it was leaking, if anybody else has water leaking through the door panel I have a solution.
    signature removed for inappropriate content.
    -bio
  1. Water in floorboard (Take 2) - The Permanent Fix
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 09-16-2022, 02:02 PM
  2. Water in Passenger Floorboard [*]
    Last Post: 08-31-2012, 07:54 PM
  3. Water on floorboard-one more time
    By Madness in forum How To Write-Ups/Tech Tips
    Last Post: 05-21-2010, 09:17 PM
  4. water in heater blower fan or water on passanger floor
    By coolcat2010 in forum How To Write-Ups/Tech Tips
    Last Post: 03-19-2010, 04:20 PM
  5. water in floorboard i need to fix
    Last Post: 06-01-2009, 12:13 AM
