Thread: Blender door or HVAC control unit problem?
Results 1 to 12 of 12
  1. #1 Blender door or HVAC control unit problem?
    SE Level Member Drive XR7's Avatar
    Cleveland, OH
    I have a 2001 GTP with dual slider air/heat controls. I took a road trip today, and noticed that with the A/C on, sometimes the drivers side would blow cold, then go warm, then go cold again. The passenger side is always cold. It seems intermittent, and I can sometimes fix it by wiggling the drivers side slider. To me, this sounds like a blend door issue.
    Then, on the way home (about 3 hours), I didn't put the A/C on because it had cooled down. I left the sliders on cold and kept the vent on. I had no strange swings in temperature like I did with A/C on. It would stay cold the whole time, and I could adjust the sliders and it would behave as I'd expect. Now, it doesn't seem like a blend door issue.
    Could this be an HVAC control unit problem? Any other ideas?
    Jason
    2001 Bronzemist Pontiac Grand Prix GTP - SOLD!
    2003 Sonic Blue SVT Mustang Cobra Convertible #2421 (1 of 340)
    2013 Ruby Red Ford Edge Limited EcoBoost
  2. #2 Re: Blender door or HVAC control unit problem?
    Apr 2015
    Columbus, OH
    Just to throw something out, but maybe it's low on freon? My sienna would do this too, and it turned out it just needed charged. One side stayed cool, and other side would fluctuate. Seemed better at certain rpm's, if I remember right. But, yeah, put a can of freon in and it has been good since.
    Top Swapped 01 Imp
  3. #3 Re: Blender door or HVAC control unit problem?
    Cleveland, OH
    Quote Originally Posted by bandook View Post
    Will try it. The system does leak and I've had to recharge it before, but I don't remember it being intermittent before.
    Jason
  4. #4 Re: Blender door or HVAC control unit problem?
    GXP Level Member
    Mar 2015
    Tomball
    Had that happen to my PA as well pass side was cold drivers side would get warm. It got warm enough that I rolled down the window and could hear the clutch cycle. It ended up taking about half a can. Check your pressures and see if the clutch cycles.
    Jeff
  5. #5 Re: Blender door or HVAC control unit problem?
    Apr 2015
    Columbus, OH
    Yeah, it was a common problem on the Sienna's with split climate control. Theory I heard was that coolant was low enough that the compressor would stay on, but only one half of the evap would get cool, which was pass side, and would be warm by the time it passed by driver side when the blower hit it.
    Top Swapped 01 Imp
  6. #6 Re: Blender door or HVAC control unit problem?
    Cleveland, OH
    Added a can, looks like that may have fixed it. I'll keep an eye on it. Thanks guys!
    Jason
  7. #7 Re: Blender door or HVAC control unit problem?
    Cleveland, OH
    Bump. After a bit more seat time, I found that even on vent, the drivers side goes warm. If I fiddle with the controls it'll go back cold again. Definitely a blend door actuator? Is there a write up on how to replace or diagnose?
    Jason
  8. #8 Re: Blender door or HVAC control unit problem?
  9. #9 Re: Blender door or HVAC control unit problem?
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    I just replaced my passenger side blend door for this issue but when testing found the motor would oscilate back and forth and then stay warm. I removed the motor and could manually move the door to cold or hot so I was relieved that was OK. Could this just be the control head?
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  10. #10 Re: Blender door or HVAC control unit problem?
    its the actuator, its crapping out. they freak out too when bad and twitch back and fourth.
  11. #11 Re: Blender door or HVAC control unit problem?
    Canterbury, CT
    Quote Originally Posted by ScottyDoggs View Post
    Problem is the new one is doing it also, I just found in another thread sometimes pulling the fuse or the battery will reset the motor. I'll try that or every six months I'll just manually flip it from warm to cold! I usually drive alone anyway and the drivers side work great!
    Just kidding I need to figure it out.
  12. #12 Re: Blender door or HVAC control unit problem?
    i did the manual turning of both sides for two years, its not that bad till you want warm air not hot.
    maybe see what the little plug is doing power wise? if its off and on or back and fourth out the plug it should be the cc gone a rye.
  1. [?] blend door actuator or HVAC control unit ???
    By localhost127 in forum General Tech Discussion
    Last Post: 08-25-2014, 06:58 PM
  2. WTB: 03 HVAC Control Unit
    By brandonl2000 in forum Wanted To Buy - Parts
    Last Post: 03-07-2013, 08:28 PM
  3. No hvac control
    By Onthebrinc in forum General Tech Discussion
    Last Post: 03-23-2008, 03:24 PM
  4. hvac control
    By Chleby in forum General Tech Discussion
    Last Post: 01-17-2008, 11:53 AM
