Thread: Ask your water methanol injection questions here.
Results 21 to 40 of 76
  1. #21 Re: Ask your water methanol injection questions here.
    they are all 1/8 NPT i believe. also, why you takin my idea with modding the blower? do it in your TB right after the MAF and before the throttle blade. that would be better really, but im just looking for something unique and im stubborn.
  2. #22 Re: Ask your water methanol injection questions here.
    DevilsOwn
    Guest
    lots of cheap places to buy methanol. Should have no problem finding some for 3.00 a gallon or so if you look. Call around to chemical supply places in your phone book. cheap windshield washer fluid
    All nozzles we sell are 1/8npt so you can do that and put a pipe plug to seal it.
  3. #23 Re: Ask your water methanol injection questions here.
    devislown what about my question?
  4. #24 Re: Ask your water methanol injection questions here.
    TDCRacing
    Guest
    Quote Originally Posted by DevilsOwn View Post
    Cool thanks. If you know of any places online feel free to share.
  5. #25 Re: Ask your water methanol injection questions here.
    DevilsOwn
    Guest
    Oh, sorry for skiping yours question. Not sure why you are seeing yours being off. Ken got the numbers directly from a grandprix 2 bar map sensor. Now there are afew that have been used thru the years and can vary some but should not be off much. If you switch your ls1m to show map sensor votage. 2.8v should be 2psi, maybe ls1m is off. I will yank mine out and look to see whos math is off.
    I would look for something local vers shipping it or ship it from the nearest town.
  6. #26 Re: Ask your water methanol injection questions here.
    Bastard Reptile's Avatar
    Kansas City, MO
    This is the stuff I use.....mix to your hearts content.
    Truck stops are wonderful places this time of year to pick this up.
  7. #27 Re: Ask your water methanol injection questions here.
    okay, just keep me posted devilsown please. ^_^
  8. #28 Re: Ask your water methanol injection questions here.
    TDCRacing
    Guest
    How much is that stuff brian. Can't get any of that stuff around here
  9. #29 Re: Ask your water methanol injection questions here.
    Moore, Oklahoma
    Hey Reptile, that stuff you posted for Meth, is that stuff 100%? Anything else in it? Just curious.
    Also, can some one help me out? To mix my own with water, what kinda water should I specifically use? Distilled? Mineral water? Tap water?
    Shawn W. Larsen
  10. #30 Re: Ask your water methanol injection questions here.
    distilled is best. if youre lazy i would use tap water, but it has so much crap in it that might do something that i wouldnt do it forever.
  11. #31 Re: Ask your water methanol injection questions here.
    Kansas City, MO
    Distilled water is the best to use....when in doubt, buy the bottled stuff at wal mart in the gallon jugs...or if you have a water purification system...like say from the fridge, that will work too. PUR pitchers are great as well, and measuring is easy.
    Shawn, that stuff is 100% Methanol with a blue dye like washer fluid, but you can also get it in clear that's by the gallon. It's a little high, at $2 a bottle, but it's readily available to me at my work, so I go ahead and use it.
  12. #32 Re: Ask your water methanol injection questions here.
    Moore, Oklahoma
    Cool, distilled it is! That all I use for my IC fluid mixtures anyway. I like it much better.
    Thanks for the info Brain. Now if I can only find 100% meth locally and priced reasonably.....
    Shawn W. Larsen
  13. #33 Re: Ask your water methanol injection questions here.
    TDCRacing
    Guest
    Quote Originally Posted by Iron Indian View Post
    That would be nice
  14. #34 Re: Ask your water methanol injection questions here.
    Moore, Oklahoma
    Since Devilsown is local and Chance was at the shop Saturday, I picked up some Devils Brew for my setup, I figured what the hell...
    Shawn W. Larsen
  15. #35 Re: Ask your water methanol injection questions here.
    Moore, Oklahoma
    Ok, so fellow ALKY users. Any kinda special PCM tuning you guys are doing to optimize you're setups? I know I need to lean out my setup during WOT. For now I got that covered with my ICCU.
    What AFR should I shoot for via wideband? Should I add timing, boost, or both? I have a brand new 2.9" non-slip DUB i've had for a couple years and have never used. I wondering if I can use that? I donno which is better, but i'd like to add boost I think. I cannot drop any lower than a 2.8" though because my snout isn't cleaarenced.
    Not sure exactly where I need to start out with my new toy....
    Shawn W. Larsen
  16. #36 Re: Ask your water methanol injection questions here.
    Kansas City, MO
    I like shooting for 12.0-12.2, it seems to give the best gains....and max timing at 25*.
    Never could get it to do any better with any higher than that.
  17. #37 Re: Ask your water methanol injection questions here.
    Quote Originally Posted by Reptile View Post
    man i dunno how u guys are able to run 12.0-12.2AFR cause i cant seem to run even 11.0-11.3 w/o getting KR on decent timing. i dunno if my plx wb is fubar'd or not but i can only run kr-free with 20* with a 10.0-10.3AFR
  18. #38 Re: Ask your water methanol injection questions here.
    TDCRacing
    Guest
    Quote Originally Posted by fst View Post
    What is you're injector duty % at?
  19. #39 Re: Ask your water methanol injection questions here.
    IDC IIRC is ranging from 76% and goes up to ~86-87% top of the gear, except in first gear as i've seen it go as high as 96% b4 shifting into 2nd gear.
  20. #40 Re: Ask your water methanol injection questions here.
    Moore, Oklahoma
    Wow, 12.0-12.2, thats pretty lean ain't it? 25 degrees timing eh? Wow, I couldn't imagine running that much timing, interesting. Guess I have a ways to go with my setup.
    What kinda boost were you running without Alky and with? I'm sure you upped the boost a little, didn't ya?
    Shawn W. Larsen
  1. Washer Fluid Injection
    By 98GT3800 in forum General Tech Discussion
    Last Post: 10-21-2008, 11:51 AM
  2. Ethanol injection
    By IndeedSS in forum Off Topic Discussion
    Last Post: 09-03-2008, 09:45 AM
