Thread: Code 1404
Results 1 to 3 of 3
  1. #1 Code 1404
    Jun 2015
    Texas
    Howdy folks.
    I had code 1404 come up on my car today so I pulled the EGR and to look it over. It looks nearly new with hardly any carbon build up on it. The plunger moves free without any resistance at all. ( I realize it may still be bad ) After some research I came across this http://engine-codes.com/p1404_pontiac.html Can someone elaborate a little more about the reprogramming the PCM. I assume this has to be done at a shop? Or dealership ? Ive been searching the multitude of threads on codes but cant seem to find an answer for this particular problem. I forgot to mention Ive only had my car for 2 weeks so Im still learning about it and unfortunately I do not have any records of previous maintenance or issues its had, if any. The car runs great but I would like to nip this in the butt before it gets worse.
  2. #2 Re: Code 1404
    that would only be if there was tsb for your car to have updated programming, not the case here.
    check the wires to its plug, if the insulation is damaged and you see bare wire, thats the issue right there.
    then theres always its just gone bad. they are cheap at the junk yard to swap out.
    or if need be i got one for sale in the for sale section here.
  3. #3 Re: Code 1404
    Jun 2015
    Texas
    Thank you sir, Ill check it out and see what I can find.
  1. Replies: 8
    Last Post: 02-21-2015, 07:08 PM
  2. HELP Needed! Car surging P0102 code and P1655 code im STUMPED
    By 97gtpjoe in forum General Tech Discussion
    Last Post: 02-06-2014, 12:15 PM
  3. bad idle maf code driver 6 line 4 code
    By GTPSHAWTY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2012, 05:56 PM
  4. '99 Grand Prix GT has code 1810, yet runs great as always, so why the code?
    By McFly1999 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2012, 07:52 AM
  5. 1404 code and EGR Valve
    By AlphaBetaBase in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 01:10 PM
