Thread: Been a while. How does this valvetrain look?
Results 1 to 20 of 29
  1. #1 Been a while. How does this valvetrain look?
    Buffalo
    So I'm using the zzp rocker shims. I used a black marker to color the tops of the valve stems. I installed all the rockers and did a few rotations by hand. Removed a couple rockers and they appear to be striking the center of the valve stem. You can see the spot rubbed away in the marker ink.
    Without the shins they were striking too far inward towards the rocker.
    So then I took it to TDC and tightened hand tight then a slight turn to snug. Repeat for all. Then turn the motor by hand a few times again just to test.
    at TDC the stock pushrods still spin and one is tighter the other. But there is no play between the lifter and rocker from what I can tell.
    I just want to be sure I don't need custom length rods either for just the intake or exhaus or both.
    My push rod length checker was the wrong style and I didn't notice until today.
    Now when I did my 1.9s and when I went back to stock rockers I don't remember these details as the heads and valves were stock
    These are zzp heads with the longer valves and I swear there is a 1mm difference in height between the intake and exhaust valve stem. One just seems to sit a slight bit higher. Zzp said its the say they did the cut on the seat ?
    http://smg.photobucket.com/user/djbobbyb/media/l26%20build/D50B65A9-ED49-41E9-BC27-EA4AD77245CF_zpsx7bkemgg.mp4.html
  2. #2 Re: Been a while. How does this valvetrain look?
    Let's take the nutty heads out of the equation for a moment. Because Bill doesn't wanna know anything about them. That's a question for James.
    At TDC, the only thing I'd be thinking of is the lifter. If they aren't both pumped up, that could cause a difference.
    To summarize, I believe you have a couple different potential things happening.
  3. #3 Re: Been a while. How does this valvetrain look?
    Buffalo
    Figures my biggest investment was my worst investment Never again....
    With the amount of rockers I've changed out, I've never been this concerned because now there is variables that I'm not used to.
    as soon as I can check OK on the valvetrain , the LIM and blower go on and I have a car to drive once again
  4. #4 Re: Been a while. How does this valvetrain look?
    Think of it this way.
    If you don't start it.. it can't break.
  5. #5 Re: Been a while. How does this valvetrain look?
    Mar 2012
    NC
    Yes, don't be like Dan.
  6. #6 Re: Been a while. How does this valvetrain look?
    Buffalo
    I feel like a noob now .....
  7. #7 Re: Been a while. How does this valvetrain look?
    Name change to Newbie03?
  8. #8 Re: Been a while. How does this valvetrain look?
    Mar 2012
    NC
    I second the motion.
  9. #9 Re: Been a while. How does this valvetrain look?
    Buffalo
  10. #10 Re: Been a while. How does this valvetrain look?
    perfect lol ^^^^^^
  11. #11 Re: Been a while. How does this valvetrain look?
    Apr 2015
    Columbus, OH
    Lol. Before I started the car after my build, I was contemplating just sticking a for sale sign on it and rolling it out of the garage, never starting it so never realizing just how bad I screwed up.
    Top Swapped 01 Imp
  12. #12 Re: Been a while. How does this valvetrain look?
    Buffalo
    yeah.... I'm just used to things being taken apart and re-assembled without a lot of guess work. I could just be over-paranoid and for all I know it will work fine.
    Or maybe I do need a longer push rod
    side note. You think stock rods and locks are OK for 130s? Wasn't sure if the 3/8 rods could fit without rubbing
  13. #13 Re: Been a while. How does this valvetrain look?
    What does ZZP say?
  14. #14 Re: Been a while. How does this valvetrain look?
    Buffalo
    They said they used spacers under the springs and regular pushrods. The shims I need to keep the valvetrain geometry in line. That part checks out. I confirmed the shims did their job to counter-act the longer valve stems.
    Now it's just the rods ....
  15. #15 Re: Been a while. How does this valvetrain look?
    Buffalo
    I re - torqued them all and I think the preload is correct but after a few cranks , some push rods, on the far ends are tight and the rest can spin They flip flop back and forth.
    So maywb the lifters need to be ran with oil to take up any slack but I don't feel movement up and down , just side to side.
    another source said there is enough give in a stock lifter to make up for small differences
  16. #16 Re: Been a while. How does this valvetrain look?
    Apr 2015
    Columbus, OH
    There's a decent amount in the spec to make up differences. Forget what I read, like 55 thou? When I pit in new lifters, tightening rockers I seen valves open that should have been shut. I thought crap, cause I had valve job and thought maybe they didn't take enough off top of the stem. So they were very tight, couldn't twist them. Rotated engine couple times by hand and the same valves I could now twist, but no lash. Engine runs quiet now too.
    First 5 minutes sucked though, lol.
    Top Swapped 01 Imp
  17. #17 Re: Been a while. How does this valvetrain look?
    Buffalo
    I'm trying to figure out a way to fill with oil and crank the motor over to prime it.
    But the oil filter neck needs to be removed to make dropping back into the car much easier.
    Aslo nothing in my garage can spin the motor over fast enough
  18. #18 Re: Been a while. How does this valvetrain look?
    Apr 2015
    Columbus, OH
    Quote Originally Posted by crazyguy03 View Post
    That's where I was totally stumped. I seen some mention that you can't check lash properly unlessbthe lifters were primed. Only way I could think to do that was to run the engine. Then how do you check lash on a running engine? Lol. Yeah I'm missing something but that was my train of thought...
    Top Swapped 01 Imp
  19. #19 Re: Been a while. How does this valvetrain look?
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Pull the plugs and remove harness/wires to the ICM and crank it over on the starter to get it primed.
  20. #20 Re: Been a while. How does this valvetrain look?
    thats my plan before the engine gets swapped. take the starter off my car, then crank the engine plugs out till i see oil pressure and oil out the push rods. i plan on doing this on the stand.
  1. Valvetrain Chatter
    By brandonl2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2014, 08:30 PM
  2. Question on valvetrain
    By bobeebob in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2014, 10:08 AM
  3. Valvetrain parts ?
    By nascartech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2013, 10:27 PM
  4. Valvetrain parts
    By synysterjoe in forum Wanted To Buy - Parts
    Last Post: 06-03-2013, 12:49 PM
  5. Should my valvetrain be ok for an S1X cam?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2011, 08:43 PM
