Thread: Arc'd battery now car won't start. PLEASE HELP!! 😩
Results 1 to 7 of 7
  1. #1 Arc'd battery now car won't start. PLEASE HELP!! 😩
    May 2015
    Maryland
    My buddy was attempting to tighten a bad positive battery terminal on my 2006 GP GXP and mistakingly arc'd the battery. He ended up replacing the terminal but when I went to start the car the chimes, lights, and radio turned on but not the car. It didn't even turn. Charged the battery (a brand new yellow top) and still nothing. Checked all of the fuses under the hood and all seem fine. Are there any fuses that if blown would cause a problem like this? Any other ideas what may be stopping the car from starting and how to fix it would be much appreciated.
    Matt
  2. #2 Re: Arc'd battery now car won't start. PLEASE HELP!! 😩
    Any IGN fuses, maybe even swap the starter relay around with another.
  3. #3 Re: Arc'd battery now car won't start. PLEASE HELP!! 😩
    May 2015
    Maryland
    Yea, this is the list I came up with yesterday:
    fuel pump fuse
    solenoid
    ignition fuse
    starter relay
    Matt
  4. #4 Re: Arc'd battery now car won't start. PLEASE HELP!! 😩
    May 2015
    Maryland
    Anyone else think of anything?
    Matt
  5. #5 Re: Arc'd battery now car won't start. PLEASE HELP!! 😩
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    sadly I'd have to add pcm to this list.
  6. #6 Re: Arc'd battery now car won't start. PLEASE HELP!! 😩
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Take a multimeter to all the fuses under the hood, check for continuity. There's two little metal tabs at the top of each fuse, put the leads on and if the meter beeps, it's good. No beep, remove and inspect. I've missed fuses just looking them over real quick, found after using the multimeter.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  7. #7 Re: Arc'd battery now car won't start. PLEASE HELP!! 😩
    May 2015
    Maryland
    It was the starter. Will be replaced TODAY!
    Matt
  1. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  2. New Battery, New Alternator, Battery still dies. Any Ideas?
    By bjornbjorn in forum General Tech Discussion
    Last Post: 03-19-2015, 10:05 PM
  3. Changed Battery and now doesnt start right away
    By blackthunder in forum General Tech Discussion
    Last Post: 06-12-2014, 12:41 PM
  4. engine cranked over until battery went dead, wouldn't start
    By twillroth in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-03-2014, 11:27 PM
  5. 2002 GT won't start, new battery. HELP?!
    By skeelo58 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2014, 09:39 PM
