Thread: How do you end up with a shorter valve spring ?
Results 1 to 11 of 11
  1. #1 How do you end up with a shorter valve spring ?
    Buffalo
    Lmao this build is getting silly - Everything Ive ordered comes from like a China sweat shop
    how can it be possible to have a 1 shorter valve spring then the rest ? (130s) it's not as short as a stock spring but not as tall as the rest of the 130s
  2. #2 Re: How do you end up with a shorter valve spring ?
    GXP Level Member
    Mar 2015
    Tomball
    Where did you get those from? That looks like a good .2" shorter lol.
    Jeff
  3. #3 Re: How do you end up with a shorter valve spring ?
    Buffalo
    Can't remember zzp or intense. It measures about 54mm vs 58mm
  4. #4 Re: How do you end up with a shorter valve spring ?
    GXP Level Member
    Mar 2015
    Tomball
    I would definitely send it back. But I would also test all the others to make sure they are in spec as far as spring rate and pressure at installed height. If you dont have the gear to do it, I can if you like.
    Jeff
  5. #5 Re: How do you end up with a shorter valve spring ?
    Kemmerer, Wyoming
    that will change the spring load quite a bit because the installed spring height lb will change so much.
  6. #6 Re: How do you end up with a shorter valve spring ?
    GXP Level Member
    Mar 2015
    Tomball
    That's why I also suggest checking the rest of them as well, to me the rest are suspect too.
    Jeff
  7. #7 Re: How do you end up with a shorter valve spring ?
    Buffalo
    Got it all figured out and making it right!
    seems there was a 105 sent along with the 130s - I checked everything else and it comes up perfect
    thanks
  8. #8 Re: How do you end up with a shorter valve spring ?
    GXP Level Member
    Mar 2015
    Tomball
    Cool, at least you caught it before you installed them.
  9. #9 Re: How do you end up with a shorter valve spring ?
    Kemmerer, Wyoming
    Quote Originally Posted by J57ltr View Post
    For sure. Mistake like that would have induced a catastrophic failure
  10. #10 Re: How do you end up with a shorter valve spring ?
    oh that short ones for the pedestals you dont have to shim........ lmfao you mean these didnt come from zzp?
  11. #11 Re: How do you end up with a shorter valve spring ?
    Buffalo
    Yeah. Word of advice to anyone - INTENSE not ZZP
    my zzp heads are crazy hard to set up - took me all day with another $80 in tools I'll never use again lmao
  1. Question on valve spring
    By BlackGT97 in forum General Tech Discussion
    Last Post: 01-14-2013, 10:17 PM
  2. Valve spring selection?
    By DaytonaGTP500 in forum General Tech Discussion
    Last Post: 05-27-2012, 03:50 PM
  3. ls1 valve spring comprssor
    By mskram1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2012, 11:39 PM
  4. valve spring seal
    By blazinzuk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2010, 07:39 PM
  5. zzp valve spring retainers
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2009, 07:35 PM
