L36 top swapped 2004 Comp G. The car ran bad, found two plug wires on wrong, fixed that and it idled great for a bit, but had NO throttle response. Put a different throttlebody on, fixed the issue, and it would raise RPMs as I pressed the pedal. Then it just died, and won't start again. No codes, either.
Definitely can smell fuel on the plugs, getting 180psi compression, and it has spark. I don't know where to go from here.. any ideas?
