Thread: Not starting, not sure where to begin
Results 1 to 6 of 6
  1. #1 Not starting, not sure where to begin
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    L36 top swapped 2004 Comp G. The car ran bad, found two plug wires on wrong, fixed that and it idled great for a bit, but had NO throttle response. Put a different throttlebody on, fixed the issue, and it would raise RPMs as I pressed the pedal. Then it just died, and won't start again. No codes, either.
    Definitely can smell fuel on the plugs, getting 180psi compression, and it has spark. I don't know where to go from here.. any ideas?
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  2. #2 Re: Not starting, not sure where to begin
    GT Level Member zipper's Avatar
    Dec 2008
    Shelby, MI
    Check the fuel pressure anyways, but it could be a number of things including the fuel pressure regulator, crank position sensor, ICM, coils, grounds, or maybe even something else. Does the ICM seem to have a lot of corrosion behind the coils?
  3. #3 Re: Not starting, not sure where to begin
    Nov 2012
    Frankenmuth, MI
    I swear... every time I make a "help" thread it ends up being something super super simple that I find right after. Somehow the fuel pump line in the tank came off the canister....... Go figure
  4. #4 Re: Not starting, not sure where to begin
    GXP Level Member
    Mar 2015
    Tomball
    Well at least it's something easy....for now.
    Jeff
  5. #5 Re: Not starting, not sure where to begin
    What made you think to check that?
  6. #6 Re: Not starting, not sure where to begin
    Nov 2012
    Frankenmuth, MI
    Honestly, I'm not sure. It obviously sounded just fine, as it was wired up the right way, it just wasn't feeding fuel. Luck, I guess?
  1. Where do I begin
    By Gordonjg1656 in forum Introductions/Noob Questions
    Last Post: 09-10-2013, 05:01 PM
  2. 99 GT Mods: Where to begin???
    By Pandion28 in forum General Tech Discussion
    Last Post: 05-10-2012, 02:52 PM
  3. 99 gp gt - begin where?
    By mvp04nv in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-21-2009, 07:29 PM
  4. Where to begin?
    By PhilsGTX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2008, 12:10 AM
  5. I am here...Let the Party Begin!
    By Lacey21485 in forum Introductions/Noob Questions
    Last Post: 01-03-2008, 12:05 AM
