Thread: alternator charging fluctuations
Results 41 to 60 of 65
  1. #1 Re: alternator charging fluctuations
    GXP Level Member
    Mar 2015
    Tomball
    That's true to a point, that's why a lot of people burn up alternators because of running too much power at low rpm and saturating the field. We don't typically idle around so the alternators RPMs at cruise are in its efficiency area so there's no point in having all this power unless you are just idling around all day. I run in half in town and half freeway and what the alternator can't supply it takes from the battery like on fan startup. The alternator can easily replenish this.
    Jeff
  2. #2 Re: alternator charging fluctuations
    Feb 2013
    Missouri
    It's a bad voltage regulator, IMO.
  3. #3 Re: alternator charging fluctuations
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    ^x2. Something like that at least.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  4. #4 Re: alternator charging fluctuations
    Feb 2013
    Missouri
    It's something with the regulator\brushes\stator ménage Ã* trois. I'd think atlernator though, because the other 2 last a long time. These alternators have very long brushes, pushing an inch long.
  5. #5 Re: alternator charging fluctuations
    GXP Level Member
    Mar 2015
    Tomball
    Do that, I've literally spent hours driving through nowheresville with only the voltage showing and it's been that way in every GM car I have driven. I first noticed this in 05' and thought it odd. So I would like to see results of your test. I have logged mine and seen the same thing 12.5-14.7.
    Jeff
  6. #6 Re: alternator charging fluctuations
    Antioch, IL
    Quote Originally Posted by J57ltr View Post
    Jeff
    Thats what I did, set to voltage and let it fly, you will see the voltage isnt "stable" at all.
    2009 Challenger SRT8
    Expert at being gay.
  7. #7 Re: alternator charging fluctuations
    Antioch, IL
    Jeff
    see above ^^^^ nothing is wrong with my charging system, go drive
  8. #8 Re: alternator charging fluctuations
    Feb 2013
    Missouri
    I should try a similar log for my 10 seconds and 2.5 second delay regulator, just to see if there is a difference.
  9. #9 Re: alternator charging fluctuations
    Feb 2013
    Missouri
    A voltage booster just sets the voltage regulator to a higher voltage, so it doesn't help stability at all. You can even put a potentiometer on the sense wire, and turn the voltage up if you wanted.
  10. #10 Re: alternator charging fluctuations
    Antioch, IL
    yup but I no longer dip into the 12's, ever
  11. #11 Re: alternator charging fluctuations
    Feb 2013
    Missouri
    The moral of the story is you shouldn't in the first place. Something is wrong with your charging system.
  12. #12 Re: alternator charging fluctuations
    Feb 2013
    Missouri
    You have a 2000. He is talking about 2005+. The only explanation for his experiences are clutches on the alternator pulleys, which you don't have. If you need something to boost your voltage to maintain normal operating voltage, you have something wrong...otherwise you wouldn't need to boost the voltage. You really need to do some research on how electronics work. Like I said, this is basic stuff.
  13. #13 Re: alternator charging fluctuations
    Antioch, IL
    I didnt say 12's was my"normal" operating voltage, again your reading into this way to hard.
    Hi my name is Corey and I juiced up my voltage for no other reason than because I can.
  14. #14 Re: alternator charging fluctuations
    Feb 2013
    Missouri
    You my friend, need an intervention. And a CS144, lol.
  15. #15 Re: alternator charging fluctuations
    Antioch, IL
    I put this alt in last year, when it dies maybe.
  16. #16 Re: alternator charging fluctuations
    Apr 2012
    Windsor
    *update*
    Alright so i replaced my old stock alternator with a new AC delco one from rockauto. The stock one was about ready to go anyways since after i took it off i noticed the bearing was kinda messed and it did not spin very well.
    So i installed the new one last night and drove it around with headlights on, It was at 14.5 the whole time so i thought i fixed it.
    Today when i drove it i noticed it did the usual thing where it started at 14.5 and by time the engine is normal operating temp it rests at 12.8.. So is this normal or is there something else i should check/replace?
    Also not sure if i mentioned before but the battery is new (1 year old) and before i installed the new alternator i removed the battery and cleaned it with a battery cleaner spray as well as the terminals so there is 0 corrosion.
  17. #17 Re: alternator charging fluctuations
    Antioch, IL
    Its normal
  18. #18 Re: alternator charging fluctuations
    GXP Level Member
    Mar 2015
    Tomball
    Your good everything is OK. I just spent more than 15 hours logging voltage from a 14 Impala and it does the same thing. My 05' does the same thing. The only time you will see it hold 13.8 is when the lights are on. The reason for this is that the lights are rated for a certain amount of output at a specific voltage and current. You would constantly notice that your lights dimming and brightening if the voltage fluctuated as much as it normally does. If you drive your car you will see the voltage jump from resting voltage of between 12.4-7 depending on condition of the battery. The voltage will go up to between 14.1-8 for a time then it will settle down to 12.7-8 and as low as 12.6. Then after a while it will increase to 13.8 for a while then drop back into the 12's. The PCM controls the alternator and has it put out only what it needs to to charge the battery and whatever excess it needs to keep it at that level. The reason for this is 2 fold, one your not cooking your battery, so it extends the battery life and 2 it cuts down on excess energy wasted running 2 volts higher than it needs to operate the cars electronics.
    Jeff
  19. #19 Re: alternator charging fluctuations
    Jan 2013
    Raleigh, NC
    Jeff
    Still not a 100% sure about this, but if you've logged that much, i have to default to your data. I looked at my logs a few mins ago that i took earlier while doing some maf tuning. Lowest value i saw was one reading of 13.5. This was over a 30 min or so drive, interstate and city streets. I'm going to take a screenshot of the Ign V sorted lowest to highest and post in a few.
    Still, if you've tested it in multiple gm vehicles, and the OP changed his and is having the same voltage drop, this may just be how they're setup. It makes sense.
  20. #20 Re: alternator charging fluctuations
    Jan 2013
    Raleigh, NC
    Not a great picture, but zoom in and you can see it better.
  1. Curious sount/Interesting temp fluctuations
    By barbschwartzer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2013, 07:52 PM
  2. Replies: 11
    Last Post: 04-24-2012, 11:47 PM
  3. RPM fluctuations
    By GeeXPee in forum General Tech Discussion
    Last Post: 04-02-2011, 04:18 PM
  4. 100 RPM Fluctuations
    By CSteen85 in forum General Tech Discussion
    Last Post: 04-16-2010, 03:25 PM
  5. voltage fluctuations DIC
    By ghostgt in forum General Tech Discussion
    Last Post: 10-31-2008, 10:15 PM
