Thread: Evaporator Core leak
Results 1 to 5 of 5
  1. #1 Evaporator Core leak
    Jan 2015
    Alabama
    My son's 05 GP has a leak at the evaporator core. Just how much of PITA is it going to be to get to it?
    Any suggestions?
    05 Grand Prix - stock, 98 Trans Am - Heavy Modified, 00 Firebird Vert
  2. #2 Re: Evaporator Core leak
    Jan 2015
    Alabama
    bump
  3. #3 Re: Evaporator Core leak
    Jan 2015
    Alabama
    bump no one?
  4. #4 Re: Evaporator Core leak
    Nov 2012
    Madison
    When I did my heater core Im pretty sure I caught a glimpse of it, further up.
    How do you know it is the core?
    Here is a link with the layout.
    http://parts.nalleygmc.com/showAssem...rimLevel=25592
  5. #5 Re: Evaporator Core leak
    Jan 2015
    Alabama
    I did a sniffer test and it only showed the leak coming from under the dash near the evaporator core. My luck it will turn out to be a stupid o ring. The car had sat a long time before I bought it. I replaced the ac line that comes off the fire wall to the dryer because there was a section that had been worn through by the transmission shift cable that someone routed it on top of, move that too so no longer an issue.
  1. evaporator
    By pitifeo in forum General Grand Prix Discussion
    Last Post: 02-28-2015, 06:15 PM
  2. advice on 98 gtp hvac evaporator core replacement
    By brevard98 in forum General Tech Discussion
    Last Post: 01-18-2015, 10:30 PM
  3. Where to buy an evaporator drain elbow?
    By vertebrate in forum General Tech Discussion
    Last Post: 08-04-2012, 02:30 PM
  4. A/C evaporator 01 GTP, how do we get it out???
    By Bunnystac in forum General Tech Discussion
    Last Post: 06-22-2012, 03:57 AM
  5. Things you might want to know about replacing the evaporator core
    By techweenie in forum General Tech Discussion
    Last Post: 08-16-2011, 09:07 PM
