At the end of the day, the vehicle doesn't know or care, so yes you can do what you asked. My concern would be light output, but I am not familiar with the '04+ cars. Maybe get or make some adapters so you don't have to cut..... just in case.
Thank you for your answer I just ended up making two o-rings so the hi beam smaller plug would fit seal the larger hole in the casing worked perfect so now my hi beams are lo beams scents I can't figure out why the lo beams won't work thank you again
