Thread: Normal Trans Operating Temperature
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 Normal Trans Operating Temperature
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    Hey guys,
    Took the car home from school today (3 hours of boredom on the interstate). When looking on the torque app, my trans temp was at 224* F. I was doing about 85 and even when I dropped to 55 for construction the temp stayed the same. That seems really high as to my dad's 2013 F150 Sits at around 195*. Is it? Think It's time to invest in a Trans Cooler? The car has 122k and the trans was rebuilt about 15k ago.
    Thanks
    Chris
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  2. #2 Re: Normal Trans Operating Temperature
    Feb 2013
    Missouri
    IMO all 4T65es should have a cooler. ASE says ATF should be 175*F and for every 20*F you increase you cut the life of the fluid in half, and at 230*F you have the potential for valves to start sticking in the valve body. ATF should last 100,000 miles or so, but companies rate set the maintenance interval at 50,000 since they run at 195*F, right around the engine temp (no external cooler needed).
  3. #3 Re: Normal Trans Operating Temperature
    Jun 2012
    Illinois
    So I should get one ASAP?
  4. #4 Re: Normal Trans Operating Temperature
    Feb 2013
    Missouri
    That is pretty warm in my opinion, I'd be a little worried. Where was your engine temp?
    I would get one, yes. I picked up a pretty cool (no pun) cooler off of an Exploder at the JY. Has mounting tabs and everything.
    Not my pic, but I remember it looking like this originally:
  5. #5 Re: Normal Trans Operating Temperature
    Aug 2013
    McDonald PA
    I snagged a Hayden cooler. A shift kit will help too. I have to do one of those next.
  6. #6 Re: Normal Trans Operating Temperature
    Jun 2012
    Illinois
    Engine temp was normal on the dash. Didn't check through Torque app tho. I go back on Sunday so i can check then.
  7. #7 Re: Normal Trans Operating Temperature
    Jun 2012
    Illinois
  8. #8 Re: Normal Trans Operating Temperature
    Aug 2013
    McDonald PA
    I got the 1405. It's gigantic
  9. #9 Normal Trans Operating Temperature
    That's the one I was looking at when I eventually get around to installing one
    Edit: I
    04 Comp G.
  10. #10 Re: Normal Trans Operating Temperature
    Aug 2013
    McDonald PA
    That's the one I was looking at when u eventually get around to installing one
    I need to find the fittings that go directly into the trans with the barb on the end for my rubber line because I want to run my cooler stand alone.
  11. #11 Re: Normal Trans Operating Temperature
    Also wouldnt hurt to make sure your duct work under the bumper isnt missing or damaged.
    The lines do run across in that area and one would think that the rushing air past them does help cool them. I might be odd ball thinking here but it might be true that it helps.
    Or maybe the factory cooler itself is semi plugged, it should stay near the coolant temp when you arent in traffic. I remember going about 240 miles without stopping and never saw over like 180.
  12. #12 Re: Normal Trans Operating Temperature
    Feb 2013
    Missouri
    The average I've seen on the site in the various cooler threads is 180-195.
  13. #13 Re: Normal Trans Operating Temperature
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    I'm thinking of getting one as well. I usually stay between 179 and 190 driving but in traffic the other day I saw 212*. No es bueno.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  14. #14 Normal Trans Operating Temperature
    Aug 2013
    McDonald PA
    I saw 235 on a 90 degree day after a 2 hour road trip what killed it was a little traffic and it never recovered. My air ducting is there. But I bought the cooler **** next day.
    Edit. I see around 170 depending on temps. I expect I'll see less once I got stand alone.
  15. #15 Re: Normal Trans Operating Temperature
    Feb 2013
    Missouri
    Careful, don't go too cold, 150* is the minimum.
  16. #16 Re: Normal Trans Operating Temperature
    Aug 2013
    McDonald PA
    Quote Originally Posted by Booba5185 View Post
    I thought 78 was. That's when the Tc locks up.
  17. #17 Re: Normal Trans Operating Temperature
    Kemmerer, Wyoming
    How long should it take to get to the minimum temperature? Mines been running cold since I replaced the radiator
  18. #18 Re: Normal Trans Operating Temperature
    Aug 2013
    McDonald PA
    Quote Originally Posted by SgtMarshal View Post
    Even in minus 10 degree weather if I let my car idle for one cycle of the remote start and drive 5 min down the road mines at 78 which I thought was operating temp.
  19. #19 Re: Normal Trans Operating Temperature
    Feb 2013
    Missouri
    I gotta find this article I read on it. Lemme see if I can...
  20. #20 Re: Normal Trans Operating Temperature
    Antioch, IL
    takes me 10 miles to even get to 115°
    2009 Challenger SRT8
    Expert at being gay.
  1. Normal Operating Temperature 97 Grand Prix GT or overheating?
    By mainecrab in forum General Tech Discussion
    Last Post: 06-16-2014, 05:40 AM
  2. 2004 - Normal Operating Temperature?
    By freebird85 in forum General Grand Prix Discussion
    Last Post: 07-28-2013, 07:58 PM
  3. Temperature, T-stat, Operating Temp
    By villanex in forum General Grand Prix Discussion
    Last Post: 11-04-2012, 09:41 PM
  4. 3800 Normal Operating Temp
    By 08 198 Champ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2012, 10:52 AM
  5. What's normal operating temperature in traffic?
    By Z28 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2010, 09:23 AM
