Thread: Misfires in park only??
Results 1 to 18 of 18
  1. #1 Misfires in park only??
    Feb 2015
    california
    I have a lightly modded 02 gtp and my car has misfires but only in park. Aeroforce says 2 4 6 8 and one time 10 misfires! Why is it multiples of two and why only in park? I get NO light and no codes and gauge doesnt tell me which cylinder is the problem. Since I noticed the misfires I have changed coils and put in 104 autolites. My wires are msd only year old (but they are the kind you have to put together yourself and cut) Maybe wires? If not it wont be cheap im thinking ICM MAF Fuel Injector or heaven forbid a chipped piston? I have a tune with overkill but could that cause a problem he knew I had stock injectors.. At least I hope...
  2. #2 Re: Misfires in park only??
    The aeroforce should tell you what cylinder it is, mine did.
    And misfire at idle with a modded 3800 is pretty normal, most people don't even know it's happening. I'd lower the plug gap or raise the idle speed to stop it.
  3. #3 Re: Misfires in park only??
    Feb 2015
    california
    when going into misfre details it says xxx for each cylinder. My plugs are .57 how do I raise idle?
  4. #4 Re: Misfires in park only??
    you need a tuner to raise it. you got a canned tune. cant raise it.
    if you had a cam you would have a code for multiple misfires. i take it you dont have a aftermarket cam.
    change the icm yet? check over the crank harness?
    gap them plugs to 0.50 too.
    im no fan of those plug wires either. cheap parts store wires work just fine.
  5. #5 Re: Misfires in park only??
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Why not keep the stock .060" gap?
  6. #6 Re: Misfires in park only??
    you too, 0.50 copper core plugs.
  7. #7 Re: Misfires in park only??
    Feb 2015
    california
    I cant tune it myself so i had to get overkill actually sent it back to be redone couple times that shipping wait sucks! and his turn around wasnt so fast either... No one near me in san bernardino CA that i know of tunes these cars. I have no cam have not changed ICM or MAF or injectors. Maybe fuel pump? I can try cheap wires see if it fixes. Not sure about the crank harness?
    I cant tune
  8. #8 Re: Misfires in park only??
    tunes ok i bet. been ok this long right?
    crank harness runs from the cam and crank sensors to the icm. they do fail.
    you do any work to it before this started?
  9. #9 Re: Misfires in park only??
    That youtube bakerxderek guy is from San bernaghetto, this is a pointless comment but it reminds me of him.
    Just try lowering the plug gap, if it's only at idle it's really a non issue. They are known to misfire at idle like I said.
  10. #10 Re: Misfires in park only??
    Feb 2015
    california
    Junk yard harness work? I have done no big work to it. not sure if its been a thing thats been getting worse where ive missed it under my radar. im not sure. My big engine work was 3.5 pulley and power log last year. Got overkill tune after and Changed accessory belt last summer. since then just installed gauges did brakes...
  11. #11 Re: Misfires in park only??
    what pugs are in it? if copper maybe they are due for a change, they only last 15k tops.
  12. #12 Re: Misfires in park only??
    Feb 2015
    california
    I thought it was plugs too had them in for atleast a year and it was misfiring so i just changed them to iridium 104 autolites. gapped 57 but No change.
  13. #13 Re: Misfires in park only??
    Kemmerer, Wyoming
    I don't like iridium plugs. had more kr with them in
  14. #14 Re: Misfires in park only??
    Feb 2015
    california
    getting 104 im definitely getting less knock but i think i want copper next time either way.
  15. #15 Re: Misfires in park only??
    Apr 2015
    I will be getting NGK TR55's. But what's the point of gapping them to .050" rather than keeping them at .060"?
  16. #16 Re: Misfires in park only??
    Quote Originally Posted by CelibateHalibut View Post
    get al 104's 50 gap works better. Fuk 60.
  17. #17 Re: Misfires in park only??
    Apr 2015
    Autolite 104's it is then.
  18. #18 Re: Misfires in park only??
    I'll answer the question better, instead of it's just better. You could have google'd this aswell.
    The spark has to jump the gap on the spark plug, having a large gap is making it's job harder. The more you mod an engine and force more air and more fuel into the motor, the harder it gets for the spark to jump the gap. There is a better possibility that the compression stroke alone could blow the spark out and not get a complete burn of the fuel. You lower the gap to make it easier to jump the gap and not be an issue. That's a simple way to put it.
  1. Misfires going 75+
    By Nchristopherson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-23-2014, 12:52 PM
  2. Misfires?
    By Ultra440 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-27-2012, 03:45 PM
  3. car misfires
    By backinblackgtp in forum Engine
    Last Post: 03-24-2011, 03:25 PM
  4. misfires??
    By paulaxe in forum Engine
    Last Post: 11-23-2010, 04:09 PM
  5. WOT misfires
    Last Post: 11-12-2008, 08:58 PM
