Thread: reading kr
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: reading kr
    your stock and n/a its gonna knock and its ok. if you can tune it out you'll get more power out of it tho.
  2. #22 Re: reading kr
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Quote Originally Posted by luckyg817 View Post
    Sorry for sort of semi bringing this thread back to life but I just had a quick question. On my 04 NA I am looking at around 5-6* of KR. I see that KR on cars that are stock is normal but was just wondering how much KR is fine until you should be concerned? And also would NA and supercharged have a different range as far as how much KR is normal for each?
    It's an NA motor so you're fine. More boost than stock + KR = bad. But you don't have that problem. I wouldn't worry about it unless you're planning on modding or doing something special to it. Even stock 3800SC cars knock. I saw 4-5+* of KR stock. No biggie.
    Also if you're worried about it, and you don't already, Put in some 93 instead of 87.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  3. #23 Re: reading kr
    Apr 2015
    Columbus, OH
    When do you see KR? When I was NA I was seeing 5-6 when shifting. Simply adding a 3" FWI, I rarely seen spikes like that again. Maybe coincidence, dunno because I didn't run NA long. But a downpipe and cai or hai will definitely help you.
    And ideally you don't want any KR when FI. You can get away with a few degrees, but it seems these pistons are easy to chip so ideally you should tune it all out if possible.
    Top Swapped 01 Imp
  4. #24 Re: reading kr
    Aug 2013
    arlington, tx
    Quote Originally Posted by bandook View Post
    I only see it when I get on the throttle. At idle I don't see any at all. I just wanted to make sure and get some peace of mind. I'm not modded yet but I will when I free up some money. Haha. I'll probably end up top swapping or swapping out the motor with a lower mileage one. I'm currently at 155k I think.
  1. Reading MAF in Hz?
    By 94GrandPrixSE in forum PCM Tuning
    Last Post: 03-28-2014, 04:13 PM
  2. How is this little gadget for reading KR and more ?
    By ryangtp89 in forum General Tech Discussion
    Last Post: 01-22-2014, 09:24 PM
  3. Torque pro app. Reading kr.
    By hollas13 in forum General Grand Prix Discussion
    Last Post: 07-19-2013, 10:36 AM
  4. DIC not reading right information
    By 1996pontiac in forum General Tech Discussion
    Last Post: 05-15-2012, 11:39 AM
  5. MAP reading
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2009, 12:34 AM
