Thread: Help please!!!!
Results 1 to 20 of 20
  1. #1 Help please!!!!
    Apr 2015
    texas
    2006 gp 3.8 non supercharged.
    The Car doesnt want to start, I replace the ICM and crank position sensor because originally there was no spark, now i have spark and plenty of fuel pressure between 50-60 psi but it still wont start. it sputters for a bit but then nothing.
    Any ideas or suggestions would be greatly appreciated
  2. #2 Re: Help please!!!!
    Unplug the MAF and try again, might have to pedal it to get it to idle.
    Quick and easy test, it will set the SES light though because you unplugged it.
  3. #3 Re: Help please!!!!
    the check engine light on? if so have you scanned it for a code?
  4. #4 Re: Help please!!!!
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    I Think you have to have a crankcase variation relearn after replacing the crank position censor. I'm not totally sure hopefully someone else can help out.
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  5. #5 Re: Help please!!!!
    Apr 2015
    texas
    no light is on, and i wondered about the relearn issue but everything ive found so far said it should still run i unplugged the maf but gotta let my battery charge its been getting cranked on for a cple days while troubleshooting
  6. #6 Re: Help please!!!!
    Quote Originally Posted by chris99gtp View Post
    that usually sets the cel and tells you it needs a crank learn.
  7. #7 Re: Help please!!!!
    double checked the plug wires are on the right plugs? it happens more then you think. hell ive done it.
  8. #8 Re: Help please!!!!
    Apr 2015
    texas
    ya did checked the wires one by one hell i even gapped and replaced the wires and plugs im at a loss to be honest i know its going to be something dumb in the end
  9. #9 Re: Help please!!!!
    leave the fuel pressure gauge on when its cranking and sputtering, maybe its loosing pressure.
    the icm, was it new or used? have you tried putting the old one back on? never know.
    and then theres always a huge vac leak, if a line has broken clean off and if large enough it can keep it from running too.
  10. #10 Re: Help please!!!!
    Apr 2015
    texas
    the icm was brand new and i put the old one back on just in case the pressure holds steady when trying to crank im pretty much at the point where im going to have to tow it to a shop and hook it up to a computer
  11. #11 Re: Help please!!!!
    what the back story that lead to the crank sensor and icm replacement?
  12. #12 Re: Help please!!!!
    Apr 2015
    texas
    i drove the car 2 hours to a job interview ran fine came out wouldnt start got it towed home and i had no spark so i replaced both the icm and crank, now i have spark but no start still
  13. #13 Re: Help please!!!!
    if you have a test light, take a injector plug off, then see if the test light flashes when your cranking it. iirc the injectors flash when the key goes to start to prime it.
    a side marker bulb also works, put it in the injector plug, it will flash too like a test light would.
    fuel pressure is one thing, is it getting gas is another.
    you can also give it a shot of starting fluid in the intake as its cranked, if it fires up your not getting gas for some reason.
  14. #14 Re: Help please!!!!
    St. Louis
    Dumb question, have you checked all of the fuses (the ones inside the car and under the hood)?
  15. #15 Re: Help please!!!!
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Even dumber question, you do have gas in the tank, right? Yes, I've seen it before, lots of troubleshooting, guys fuel guage didn't work and the problem turned out to be he ran out of gas.
    Also, did you get the crank sensor at autozone or something? I wouldn't trust that shiz.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  16. #16 Re: Help please!!!!
    Honestly..
    Unplug the maf. Most don't realize the common things that stop our cars from starting.
  17. #17 Re: Help please!!!!
    Cibolo, TX
    That was the very first suggestion, I sure hope he tried that already.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  18. #18 Re: Help please!!!!
    Apr 2015
    texas
    I have unplugged the maf didn't work. I checked the injectors all are working. One mechanic suggested it was vapor locked so I took all the plugs out and let it sit in the hot sun for 6 hours and no difference. I can't figure it out and I tried to drag it to a shop to hook it up today but nope I live in the damn twilight zone and both shops with the computer I need are closed on Fridays. Frustration is building. I will say I've been on a lot of forums for various cars in the past and everyone on here is very responsive and helpful so thanks for that.
  19. #19 Re: Help please!!!!
    Apr 2014
    CT
    Quote Originally Posted by lancej View Post
    timing? balancer put on properly?
  20. #20 Re: Help please!!!!
    GXP Level Member
    Mar 2015
    Tomball
    if a mechanic said it might be vapor locked, don't talk to that idiot again. Where in Texas are you? I have a reader and most any other tool imaginable. I'm near Houston, but I'm in Wisconsin and Illinois this week. If your close I don't mind helping.
    Jeff
