Thread: How hard is it to...
Results 1 to 8 of 8
  1. #1 How hard is it to...
    Apr 2015
    Tulsa
    How hard would it be to do the u-bend delete myself? Assuming I can get my butt under the car, would it be that hard to replace with the straight piece?
    00' GTP- CAI, HID's and a u-bend delete is all I have done so far, but I am just getting started.
  2. #2 Re: How hard is it to...
    Nov 2011
    NY
    No, easy as pie! Is why it's one of the easiest mods with most benefit. But I would recommend considering installing headers instead and set yourself up for whatever mods you may want in the future. Will make things breathe even better. But if it seems too much for you, then the Ubend delete is a good place to start.
  3. #3 Re: How hard is it to...
    Sep 2014
    Worcester, MA
    How hard is it to make a relevant subject line?
  4. #4 Re: How hard is it to...
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    I also suggest a set of Headers.
    Pick up a set of Speed Daddy Headers off eBay. $220ish to your front door.
    Headers are the "foundation" to modding in my opinion. Since they can be bought for so cheap now, I would suggest definitely going that route.
  5. #5 Re: How hard is it to...
    May 2008
    Schuyler, NE
    If you are just going to install the u-bend, you need a welder. I would buy a 3" downpipe instead. That will bolt right in, and take care your ubend as well.
  6. #6 Re: How hard is it to...
    Apr 2015
    Tulsa
    Cool, thank you for the help and suggestions! The only reason I was going the u-bend delete route was due to money issues.
  7. #7 Re: How hard is it to...
    Nov 2011
    NY
    Better off to wait, save and do the right job (headers), than spend less and get 1/2 the benefit for the $...
    Strickly my opinion : )
  8. #8 Re: How hard is it to...
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Does "doing the job right" mean going with a set of TOG's or zzp headers then? Surely using the cheapo knockoffs of slp's isn't considered doing it "right", is it?
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  1. How hard would it be
    By sureshotian1 in forum 04+ Specifics
    Last Post: 01-10-2015, 02:54 AM
  2. How hard to add HUD to car?
    By genki in forum Visual/Body Modifications
    Last Post: 08-27-2013, 06:29 AM
  3. Working hard...or HARD at work
    Last Post: 05-03-2013, 01:19 PM
  4. 97 gtp trand shifting hard from 2nd to 3rd gear.update!!!! shifts hard in every gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2012, 12:18 PM
  5. How hard is it to....
    By GTP4 in forum PCM Tuning
    Last Post: 10-27-2008, 08:30 AM
