Thread: What is the diameter?
Results 1 to 11 of 11
  1. #1 What is the diameter?
    GXP Level Member
    Mar 2015
    Tomball
    What is the supercharger crank pulley that drives the supercharger. Looking for the closest to the exact diameter to do some calculations.
    Thanks,
    Jeff
  2. #2 Re: What is the diameter?
    The pulley on the supercharger shaft is the same size as the motor, best way to remember.
    So 3.8 inches. If stock motor.
  3. #3 Re: What is the diameter?
    GXP Level Member
    Mar 2015
    Tomball
    Crankshaft pulley diameter.
    Jeff
  4. #4 Re: What is the diameter?
    Oct 2014
    portland oregon
    the balancer?
  5. #5 Re: What is the diameter?
    I found somewhere that says 7-5/32nd.
  6. #6 Re: What is the diameter?
    GXP Level Member
    Mar 2015
    Tomball
    The diameter of the dampener where it drives the supercharger. I want to know the drive ratio.
    Thanks Fivefingerdeathpunch, I'll use that for now.
    Jeff
  7. #7 Re: What is the diameter?
    GXP Level Member
    Mar 2015
    Tomball
    I'm not sure that's right according to my calculations the boost would be too low.
  8. #8 Re: What is the diameter?
    Then look up any parts store that sell them. They should all provide details on the product.
    Length and width are given.
  9. #9 Re: What is the diameter?
    GXP Level Member
    Mar 2015
    Tomball
    I tried that couldn't find a listing for the supercharged unit. I removed my belt and measured the circumference and came up with 22.75" so right at 7.25" diameter, just about what you said.
    Here re are the numbers I came up with for blower drive ratio based on the previous to Gen V blower.
    3.8" pulley DR 1.908:1= 7.49 psi
    3.6" pulley DR 2.014:1= 8.72 psi
    3.4" pulley DR 2.133:1= 9.88 psi
    does this sound about right?
    Jeff
  10. #10 Re: What is the diameter?
    The way I see it, there are too many variables.
    Ambient temps, heat from the supercharger, exhaust flow and intake air flow are just some.
    Just the stock numbers seem to be right in the ball park, they normally make right around 7-8ish psi with stock everything.
    I wouldnt doubt that if someone tossed a 3.4 on a gen v blower with stock everything else it would make nearly 11-12 psi of boost, enough to kill that motor quickly.
  11. #11 Re: What is the diameter?
    GXP Level Member
    Mar 2015
    Tomball
    Well there aren't really that many variables, and all of them combined will only account for a +/- .5 psi difference based on experience with other supercharged cars using the M90 and M112. These readings are typical of a car with stock type cam moderate exhaust and free flowing intake. Ported heads, headers and cams with lower than 112* LSA tend to have lower boost pressures, since boost is really nothing more than the inabality to pass the air from the supercharger through the engine.
    one of the parameters I use in the calculation is barometric pressure and that makes the highest difference. I just wanted to see ihow well the formula I used works for the 3.8l SC'd engine too.
    Jeff
  1. Down pipe diameter
    By traildog in forum General Tech Discussion
    Last Post: 02-05-2014, 06:25 PM
  2. Diameter of the fog lights?
    By bradical in forum General Tech Discussion
    Last Post: 12-15-2012, 06:53 AM
  3. Tire Diameter
    By gpgt04 in forum Tires & Wheels
    Last Post: 10-01-2009, 08:41 PM
  4. 4" outside diameter
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-28-2008, 03:38 PM
  5. Radiator Hose Diameter
    By 03GPScottyd in forum General Tech Discussion
    Last Post: 05-20-2008, 03:01 PM
