Thread: Clean carbon from piston head
Results 1 to 20 of 29
  1. #1 Clean carbon from piston head
    GT Level Member Xorbex's Avatar
    Canada
    With the heads off what is the best way to clean carbon deposits from the piston head. I was thinking steel wool and a brass brush with the shop vac running.
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  2. #2 Re: Clean carbon from piston head
    St. Louis
    I'd probably just leave it alone. You don't want anything like steel wool leaving small burrs behind even if using a shop vac. I guess you could use some kind of spray cleaner on it designed to remove carbon and then vac it out.
  3. #3 Re: Clean carbon from piston head
    SE Level Member transam24's Avatar
    Dec 2011
    NY
    You can try using oven cleaner, or just run some seafoam through it
  4. #4 Re: Clean carbon from piston head
    May 2008
    Schuyler, NE
    I would recommend leaving it there.
  5. #5 Re: Clean carbon from piston head
    hangover park IL
    Put at tdc n carefully scrape it off with a pile of new razor blades and old credit cards for the radiused edge of the dish
    ~James~ Psychotic Gearhead
  6. #6 Re: Clean carbon from piston head
    Buffalo
    Quote Originally Posted by Turbocharged400sbc View Post
    Exactly what I did but I used carb cleaner on a rag to help loosen it up before scraping
  7. #7 Re: Clean carbon from piston head
    Canada
    I was going to use the non metal "steel wool" and some brake cleaner along with the shop vac to clean up debris as good as possible.
  8. #8 Re: Clean carbon from piston head
    These.
    Little rubber/plastic fingers on them, work awesome removing stuff like that. I always use them to clean gasket surfaces on cars.
    3M bristle discs.
  9. #9 Re: Clean carbon from piston head
    hangover park IL
    Do not use those.
    carbon is abrasive enough. No need to toss in aluminum oxide too.
    with clean new razor blades it is extremely easy to push the carbon off the top of the piston towards the dish to keep crap out of the ring gap. A thin swipe of grease around the edge as it sticks up above the deck at tdc... will help keep it out.
    then turn it down slowly towards bdc while wiping the grease and carbon off the bore.
  10. #10 Re: Clean carbon from piston head
    hangover park IL
    Rinse and repeat x6
  11. #11 Re: Clean carbon from piston head
    Always a personal opinion here, I'll continue to use them.
  12. #12 Re: Clean carbon from piston head
    May 2012
    Where winter never ends
    Run e85??
    2000 Regal - Winter Beater
  13. #13 Re: Clean carbon from piston head
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Super lazy way. Convert car to e85. Drive it like it owes you money. Pistons will be absolutely spotless. I swear I could have rubbed them on a white cloth and not made the cloth dirty when I was replacing my explodified engine.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  14. #14 Re: Clean carbon from piston head
    Mar 2014
    Tucson
    Quote Originally Posted by Frosty View Post
    No way. Really? Are you running an EGR?
    I would love to see tear down pictures of an E85 fed engine.
  15. #15 Re: Clean carbon from piston head
    May 2012
    I was there, clean as a whistle no carbon and no him and I are not
  16. #16 Re: Clean carbon from piston head
    Apr 2011
    South Dakota
    There is a potato cam photo in there of my clean engine / shattered pistons. 160 or so thousand miles on the engine. 20,000 on e85.
    http://www.grandprixforums.net/threa...e-replacing-it
    I love Decker<3
  17. #17 Re: Clean carbon from piston head
    hangover park IL
    its the personal opinion of GM that you not use them unless the assembly being "surface prepped" is able to be completely cleaned before installation into/on the engine
    roloc brillo pads as well as the bristle pads. you may be thinking of the earlier (i believe around 98/99) TSB where GM said you may use the bristle discs but GM does not endorse the use of "these products or similar" i believe in 01 they released a superseded TSB that banishes the bristle discs to non internal engine/trans work as the brillo pads before....turns out they were still destroying engines..... and instead reiterates the plastic scrapper/clean razor blade methods
    http://chicagoengines.com/tech/bulle...ning-Discs.htm
    search for the roloc TSB or surface conditioning TSB. youll find one from every major manufacturer.
    basically dont use em unless you can then completely clean the part/crevices that can catch the abrasives.
  18. #18 Re: Clean carbon from piston head
    I would not use anything as harsh as a razor personally.
    I prefer to spray brake cleaner on a rag and wipe them off. If there's more buildup. Get a plastic/nylon dish scrubber
    http://www.alibaba.com/product-detai...580410584.html
    A little brake clean, a little scrub and you won't ever hurt the coating on the pistons.
    Here's what they should look like when you do it properly.
  19. #19 Re: Clean carbon from piston head
    Canada
    Yah bill that sounds good. What about putting some grease around the top of the piston head to prevent debris from getting into the rings? Id convert to e85 if we had it. Corn gas is hard to come by in my area... non existent to be exact.
  20. #20 Re: Clean carbon from piston head
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    What about leaving the carbon, and having a tiny bit higher compression because of it?
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  1. Replies: 8
    Last Post: 08-20-2015, 07:52 AM
  2. WTB: ARP Head Studs & Head Gaskets, FelPro or Multi Layer
    By JordanGT in forum Wanted To Buy - Parts
    Last Post: 03-05-2015, 12:51 AM
  3. Best and Easiest Way to Clean a Cylinder Head
    By Speedy1973 in forum General Tech Discussion
    Last Post: 06-29-2012, 06:17 AM
