Thread: Resonator question
Results 1 to 14 of 14
  1. #1 Resonator question
    MINNESOTA
    So I am replacing my headers and figured that I should replace the resonator and the tips at the same time
    It had a crack on it, the resonator
    So I ordered one from rockauto and this is what I got
    http://
    As you can see it looks a little bit shorter then the original one, will it still work
    I also got the tips but I don't know if I should weld the or screw them on
    They have like screw on clamps on the end
    What do you guys think?
    Thanks
  2. #2 Re: Resonator question
    Aug 2013
    McDonald PA
    It'll work and I would just clamp the tips where you want them. Then tack them on
  3. #3 Re: Resonator question
    since it needs to be welded on the res will work.
    the tips most seem to have them welded on the car so you know they are on straight.
  4. #4 Re: Resonator question
    MINNESOTA
    Cool, thanks
    Hope everything goes OK
    Thanks again
  5. #5 Re: Resonator question
    Oct 2011
    Toledo, OH
    I doubt it will fit.
    You'll assume it fits and then weld up your exhaust off the car but then find that when you tighten the flange bolts the hangers will pull the whole exhaust forwards and it'll bang on stuff. So then you have to goto a parts store, buy a coupler, re-cut the exhaust, tack weld the coupler in and say **** it and take it to a muffler shop to have them weld the coupler in so you don't have to lift your car again and take the whole exhaust off again to weld it yourself.
    7"
  6. #6 Re: Resonator question
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by industrialfish View Post
    Of course it won't fit if you do it this way. Do it properly and all will be fine.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: Resonator question
    that has to be welded in while up in the car, so the flange meets up right, they may have to add a few inches of pipe to the res.
    dont try to pre weld that up.
  8. #8 Re: Resonator question
    MINNESOTA
    Got it, thanks
    I was thinking of going to the parts store and getting a coupler today
    And about welding it after I put it back on is a good idea
    Thanks again
  9. #9 Re: Resonator question
    yeah, bolt that res in, then put the mufflers up in their hangers and then weld it up pipes hung. if need be tack it up, then take the flange bolts out and a few the front hangers and you should be able to weld the top of the pipe.
  10. #10 Re: Resonator question
    MINNESOTA
    Thank you
    I will post some pics when I get done
    Tomorrow I hope
    Thanks again
  11. #11 Re: Resonator question
    MINNESOTA
    Finally we have a good day here in MN
    I am trying to figure out the Diameter of the muffler, is it 2 1/4 or 2 1/2
  12. #12 Re: Resonator question
    Stock mufflers are 2.25
    04 Comp G.
  13. #13 Re: Resonator question
    MINNESOTA
    Ok, so I need to get 3" to 2 1/2 OD
    Does that sound right
  14. #14 Re: Resonator question
    MINNESOTA
    Ok, finally got done
    http://i977.photobucket.com/albums/a...412_172256.jpg
    the tips look like they came out to low
    http://i977.photobucket.com/albums/a...412_172154.jpg
    I didn't take any pics of the way I welded the resonator cause I didn't do a good job
  1. Resonator piping question?
    By Pokealong1227 in forum General Tech Discussion
    Last Post: 01-05-2013, 07:07 PM
  2. resonator
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-16-2011, 06:14 PM
  3. Resonator question - Walker vs. Magnaflow
    By Infinity9999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2011, 01:00 PM
  4. resonator delete question
    By ham4864 in forum General Tech Discussion
    Last Post: 12-09-2010, 11:52 PM
  5. resonator exhaust question!
    By colindunn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 03:30 PM
