Thread: Gas can damages gas tank hole flap. Now pump keeps cutting off
Results 1 to 3 of 3
  1. #1 Gas can damages gas tank hole flap. Now pump keeps cutting off
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    I am using a newer gas can with some sort of safety valve tip. And it did something to the gas tank whole. It yanked the metal flap out or down I cant see it anymore.
    Now when trying to fill up the pump keeps cutting off. I can use a basic gas can and or funnel.. can this be fixed?
    I can look in the while and see what looks like some sort of clip. the little metal door is not visible.
  2. #2 Re: Gas can damages gas tank hole flap. Now pump keeps cutting off
    the flapper is now blocking the hose. we got a screen or something in our filler tubes to keep thieves out of the tank. that flap i bet is laying over the screen.
    the pump turns off because the filler neck is filling up and the pump quits pumping, the funnel is a much slower fill.
    id check another car and see if its brass or not, aka will a magnet stick to it. if so try to fish it out with a long magnet, or one on a string maybe.
    if it dont stick to a magnet its time to take the filler hose off the tank.
  3. #3 Re: Gas can damages gas tank hole flap. Now pump keeps cutting off
    Aug 2012
    Chicago
    Thanks scotty !!! Will do..
  1. Help with cutting out 98 GP
    By lgboogie19 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-11-2013, 10:33 PM
  2. 4ch Amp Cutting In and Out
    By 2dee11 in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2013, 05:50 PM
  3. Cutting a hole in the roof
    By z3r0 in forum Visual/Body Modifications
    Last Post: 04-22-2011, 11:52 AM
  4. Metal Gas Tank Flap Broken off and Into Tank
    By indplsin72 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2008, 08:35 PM
