Thread: Stumped with p1133 and p0137
Results 1 to 12 of 12
  1. #1 Stumped with p1133 and p0137
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    Hello all,
    I've been having troubles with these codes for a while. P0137 (Oxygen o2 Sensor Circuit Low Voltage (Bank 1, Sensor 2) and P1133
    (HO2S Insufficient Switching Sensor 1) have been giving me a hard time for a while now. I have replaced the Front o2 Sensor Twice (deco) since I have put the headers in. I am almost positive that the wiring for the o2 Is fine. It has a homemade extension and then the zzp extension going to the sensor. All connections are good and the wires look good. I was getting horrible gas mileage lately and I just replaced the front o2 again and now the mileage is up and normal (almost 28 on the highway going 60-70). I have to take the car to school tomorrow (216 miles) and want to make sure that I'm safe. I've read that sometimes headers throw the p1133 code in general and I'm looking into getting a tune from reptile and getting it tuned out. (There is an intense pcm in my car now and i've had it there since I bought it). My question is, do you guys think p0137 is getting thrown because of p1133? I have a denso rear o2 sitting in the garage and might throw it on today to see if that helps. Any other ideas on this whole code deal?
    Thanks a lot,
    Chris
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  2. #2 Re: Stumped with p1133 and p0137
    this code looks to point to the post cat o2 http://www.obd-codes.com/p0137
    the other one says the upstream sensor, http://engine-codes.com/p1133_chevrolet.html
  3. #3 Re: Stumped with p1133 and p0137
    Jun 2012
    Illinois
    does one being bad effect the other one? Should I change the rear o2? Code tuned out a good idea?
  4. #4 Re: Stumped with p1133 and p0137
    thats a code for each, they do their own things. if one code triggers the other it will say it in the links i posted.
  5. #5 Re: Stumped with p1133 and p0137
    Nov 2011
    NY
    1133 is common problem with header install... Most remove the code reporting in tune. Otherwise, relocating the O2 sensor location is the only option that'll work. Some have drilled a bung into the rear header for the O2, but then you're only sniffing one side of the engine, lol... Pick your poison! There's many a thread on the subject : )
  6. #6 Re: Stumped with p1133 and p0137
    Bastard Reptile's Avatar
    Kansas City, MO
    The 1133 code is mostly the sensor itself. Run a scanner on a factory stock one, then compare it to the newer Denso ones. They read completely different and sometimes they don't agree with the pcm.
  7. #7 Re: Stumped with p1133 and p0137
    Kansas City, MO
    I say "mostly" because the placement on the headers also plays a role in the delayed reading. Stock manifolds will still throw that code on occasion but not trip an SES light.
  8. #8 Re: Stumped with p1133 and p0137
    Jun 2012
    Illinois
    Little update, Ran the car for 300 miles after I replaced the rear o2 Sensor. Still nothing so so far so good. If the p1133 code comes back, be ready reptile.
  9. #9 Re: Stumped with p1133 and p0137
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    P1133 is sometimes just caused by headers. Also leaky headers will cause it. A lot of guys relocate the front O2 to the crossover and have good luck with that. Or just turn the code off with hptuners
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  10. #10 Re: Stumped with p1133 and p0137
    Jun 2012
    Illinois
    Still so far so good since I changed the rear o2. I'm assuming no news is good news. Car still just hasn't been running great. Doesn't seem to have the power it used to lol.
  11. #11 Re: Stumped with p1133 and p0137
    Nov 2014
    BFE,Ohio
    Did the p1133 ever come back? I just installed headers and something is happening I didn't reinstall the rear o2 as my old one was seized in old down pipe I'm wondering if no rear causing the code for the front as well
  12. #12 Re: Stumped with p1133 and p0137
    Jun 2012
    Illinois
    As of now, I haven't gotten the code since
  1. p1133 ?? what is this code
    By 1bad3800 in forum General Tech Discussion
    Last Post: 12-14-2016, 12:12 PM
  2. engine code P1133
    By SgtMarshal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2014, 08:54 AM
  3. P0137 code after sd header install
    By GrandPrix06GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2013, 08:21 PM
  4. P0137, P0327 codes question
    By GTLGDP in forum General Tech Discussion
    Last Post: 12-16-2011, 03:38 PM
  5. p1133 code
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2011, 10:57 PM
