Thread: How to Install an Air/Fuel guage?
Results 1 to 6 of 6
  1. #1 How to Install an Air/Fuel guage?
    Apr 2015
    Tulsa
    First off I would like to say that I am a new member and that I am really happy to be here. I was just wondering how to install an Air/Fuel gauge in my car? Everything that I have read says to not mess with the wiring coming off the o2 sensor because it's shielded. So I was wondering where should I tap into it from? Any help would be greatly appreciated.
  2. #2 Re: How to Install an Air/Fuel guage?
    Real Air fuel gauge have there own sensor like this.
    If you bought/have a narrow band air fuel gauge like this, then all that does is give you a light show. It's never accurate or valid in anyway.
  3. #3 Re: How to Install an Air/Fuel guage?
    Apr 2015
    Tulsa
    Yeah I did get the narrow band gauge, so I guess I'll have to go get the wide band gauge instead. Thank you for your help.
  4. #4 Re: How to Install an Air/Fuel guage?
    May 2012
    Where winter never ends
    Thread moved to General as this isn't a how to write up.
    Narrowband is absolutely useless under heavy load -- get a wideband and run it along side the factory o2
    2000 Regal - Winter Beater
  5. #5 Re: How to Install an Air/Fuel guage?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    I had a narrowband once, and it got extremely annoying after about 1 day after install. It's useless.
    To read AFR accurately, you need a Wideband. I have the one pictured above, AEM. I want to say it's roughly $150 or so off eBay, but well worth the money. It comes with it's own o2 sensor, so all you do is get a bung welded somewhere in your downpipe, most likely near your factory o2 sensor, and then screw the AEM o2 sensor into the new bung. Then run the wires up to your gauge.
  6. #6 Re: How to Install an Air/Fuel guage?
    Banned
    Jan 2013
    Colorado
    for a narrow band it's gonna be a wire off the o2 sensor on your car. probably a green wire
  1. guage install
    By t wizzle17 in forum Audio, Security & Visual Electronics
    Last Post: 04-26-2013, 02:30 PM
  2. Fuel Guage not working
    By Storm Smith in forum General Tech Discussion
    Last Post: 05-02-2012, 07:45 AM
  3. Please help fuel guage and gas spillage.
    By shadowcat11 in forum General Tech Discussion
    Last Post: 06-17-2009, 12:18 PM
  4. Fuel pressure guage question?
    By basshead42 in forum General Tech Discussion
    Last Post: 03-27-2009, 12:36 AM
