Thread: wideband all used up?!?!
Results 1 to 6 of 6
  1. #1 wideband all used up?!?!
    GTP Level Member
    Jan 2015
    Lincoln, NE
    how can you tell when your wideband is shot?
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  2. #2 Re: wideband all used up?!?!
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    It doesn't work.
  3. #3 Re: wideband all used up?!?!
    Depends on the wideband, some have tests or calibrations you can do to the sensor.
    But if the sensor itself is over 15-20k miles, you should replace it anyway.
  4. #4 Re: wideband all used up?!?!
    GTP Level Member
    Jan 2015
    Lincoln, NE
    i have had it since 2008 and have probably put 20,000+ miles on it since i got it. it reacts a bit odd sometimes but doesnt lock up but seems to jump around more then it should. i dont have anything to compare it to as i havent been on a dyno with the new trans yet. i do remember the last time i was on a dyno the afx the dyno operator used reacted considerably slower then my innovate. its a bosch sensor.
  5. #5 Re: wideband all used up?!?!
    Waukesha, WI
    wrap a rag in break cleaner and hold the sensor in it, if the gauge doesnt change then replace
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  6. #6 Re: wideband all used up?!?!
    Buffalo
    I noticed mine reads lean almost all the time. Happened right at the end of the season. Hoping a new sensor will correct this.
  1. WTB wideband
    By 97AutoXVette in forum Wanted To Buy - Parts
    Last Post: 04-15-2014, 11:28 AM
  2. Wideband
    By Wrongwayislost77 in forum PCM Tuning
    Last Post: 02-28-2011, 12:51 PM
  3. AEM Wideband o2
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2010, 04:23 PM
  4. Wideband
    By TurboGTP in forum Turbo
    Last Post: 12-17-2009, 11:36 PM
  5. Wideband AFR where should....?
    By GTP4 in forum PCM Tuning
    Last Post: 04-21-2009, 11:57 AM
