Thread: Tuner vs Overkill PCM
Results 1 to 11 of 11
  1. #1 Tuner vs Overkill PCM
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    What's up ppl been awhile since I have been on due to laptop being a POS and stop working. So this is coming from blackberry so bare with me plz. I have a ZZP PCM atm and HATE it. Shifts so retarded. Question is, should I get overkill pcm or tuner? I don't know a lot about tuning so I have stayed away from it. I hear Will is the man when it comes to tuned pcms. What should I do?
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  2. #2 Re: Tuner vs Overkill PCM
    if you refuse to learn to tune and buy a tuner (at least $300) then will is your best bet.
  3. #3 Re: Tuner vs Overkill PCM
    TDCRacing
    Guest
    A tuner will always win over a tuned pcm, No matter who does them. And that's on any car.
  4. #4 Re: Tuner vs Overkill PCM
    i refuse to buy a tuner or learn how, but i have friends into ls1's with HPTuners.
  5. #5 Re: Tuner vs Overkill PCM
    Feb 2008
    Nashville
    I'm just not sure about messing with it myself. 1 mistake and engine goes poof. It would be nice to have tho. How much would I be looking at for everything I need?
  6. #6 Re: Tuner vs Overkill PCM
    depends..you can snag a DHP powertuner for ~$300, but if you get into HPTuners youre looking at around $500.
    you also need a laptop to run it and all the accessories..
  7. #7 Re: Tuner vs Overkill PCM
    Feb 2008
    Nashville
    Does the Tuner come with everything? Or is there extra software I need to purchase along with it?
  8. #8 Re: Tuner vs Overkill PCM
    tuner comes with everything you need. just need to have a laptop to put it on.
  9. #9 Re: Tuner vs Overkill PCM
    May 2008
    Olmsted Falls, OH
    Couldnt you setup a desktop computer in your garage to run it?
  10. #10 Re: Tuner vs Overkill PCM
    yes. you could do that but youd have no way to scan then while youre driving.
  11. #11 Re: Tuner vs Overkill PCM
    TDCRacing
    Guest
    Enless you got the ''PRO version''
  1. Tuner help in CT
    By 07 GPGT in forum Northeast
    Last Post: 04-04-2009, 11:25 PM
  2. DHP tuner?
    By David99GTP in forum Off Topic Discussion
    Last Post: 08-13-2008, 09:03 AM
  3. Performance Tuner?
    By NKYspdemon in forum Off Topic Discussion
    Last Post: 06-06-2008, 05:11 PM
  4. New power tuner
    By Deeter in forum PCM Tuning
    Last Post: 05-26-2008, 09:32 AM
