I just picked up a 98 grand prix gt.
Here's the problem. It will randomly just start smoking like crazy and fall on its butt. I scanned it for codes and i get misfire on cylinder one, lean code, and coverter lockup.. I changed the oil, put a new fuel filter on it, and changed the plugs. Number 1 plug was the only one that looked bad. Car ran great till about 5 min from my house and it started up smoking again. This time it gives me Random misfire, lean code, along with the coverter lockup.
So today i check the fuel pressure regulator and its fine. So i figure i will check it again when it starts smoking again. Well i drive all around and now it won't do it again. I still get the lean codes and later on i got a coverter lockup code again.
The owners before me cut the cat out of it and welded in straight pipe. I also know there is a slight exhaust leak at the resignator. So im thinking that might be were my lean codes are coming from?
So if anybody has any ideas what is causing any of this let me know.
