Thread: DIY intake
Results 1 to 20 of 33
  1. #1 DIY intake
    Jan 2015
    Michigan
    hey i want to make a diy intake. I heard that a 4inch 45 degree tube would be good. Just wanted to check. also how did you to the air intake temp sensor? just drill a hole and get a rubber gasket or whatever the proper term is. also what brand filter should i get k&n or a cheaper version? thanks for any help
  2. #2 Re: DIY intake
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Spectre filter. Either drill a hole or just leave the iat sensor out. I've seen it done both ways, but you might get a code if you leave it hanging there. As for the tube part, I've seen a bunch of different approaches to that. Some guys buy aluminum piping, some use pvc, some use that flexible rubber tubing stuff. There are threads on how to do this in the how to section.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  3. #3 Re: DIY intake
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    I run a spectre filter clamped onto the throttle body. works fine for me
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  4. #4 Re: DIY intake
    Aug 2012
    Quote Originally Posted by chris99gtp View Post
    That is what I do as well lol.
  5. #5 Re: DIY intake
    GT Level Member KoldAsIce's Avatar
    Mar 2013
    Staten Island, NY
    What do you guys do for the ait? Breather filter?
    Sent from my SGH-M919N using Tapatalk
    ZZP 10.3mm Wires, Autolite 605s, CAI, HP Tuners PCM,
    3" Catted DP, Straight Piped, 20% Tint, 5k HIDs, 6k Fogs
    220a (eBay) Alt , RF Prime Amp 1333w (RMS), Kicker 12" L7 750w (RMS), RF PBR Amp 75w (RMS x4)
    Alpine Type R (Front 5.25" 90w (RMS Each), Rear 6"x9" 100w (RMS Each)
  6. #6 Re: DIY intake
    slap a pipe in the tb, drill a hole put the ait sensor in the hole. put the hole in the same stock location.
    whats a breather filter?
  7. #7 Re: DIY intake
    Mar 2013
    Staten Island, NY
    A breather filter is a little filter think of a valve filter.. I'm sure you know what I'm talking about
  8. #8 Re: DIY intake
    no idea wtf your taking about. "still"
    we use a pcv valve, not a breather on the valve cover cap. and theres only one filter on a intake. and its in your stock air box or a open cone air filter if you removed the stock air box to make a diy intake.
  9. #9 Re: DIY intake
    Mar 2013
    Staten Island, NY
    [IMG] http://www.roadraceengineering.com/i...lledonhose.jpg /IMG]
  10. #10 Re: DIY intake
    Mar 2013
    Staten Island, NY
    That dude smh you act like you know everything but apparently you don't because people use valve cover breathers I will get a picture of it too
  11. #11 Re: DIY intake
    Mar 2013
    Staten Island, NY
  12. #12 Re: DIY intake
    Mar 2013
    Staten Island, NY
    http://www.google.com/imgres?imgurl=...QMygMMAw<br />
  13. #13 Re: DIY intake
    Mar 2013
    Staten Island, NY
  14. #14 Re: DIY intake
    Mar 2013
    Staten Island, NY
    I put the link I can't get the picture to work
  15. #15 Re: DIY intake
    Quote Originally Posted by KoldAsIce View Post
    http://www.google.com/imgres?imgurl=...d=0CCgQMygMMAw
    we dont ever use that on our cars. it lets un metered air in the engine. we use a pcv once again. only turbo guys need to use that breather on the v/c.
  16. #16 Re: DIY intake
    Mar 2013
    Staten Island, NY
    Yes I no only turbo guys use it actually I wasn't debating the reason I was saying for the iat but you are right you know everything about everything even when it has nothing to do with the topic at hand genius!
  17. #17 Re: DIY intake
    why would you put a filter on the ait hole? you need that sensor so the engine knows what the "air intake temps" are "ait" sensor.
  18. #18 Re: DIY intake
    Mar 2013
    Staten Island, NY
    They were saying let it hang out in the open.. I've heard wrong or not of people using filters to put the ait in.. I'm not gonna do it regardless I have a actual CAI I was just curious
  19. #19 Re: DIY intake
    SE Level Member Jeckel's Avatar
    Feb 2010
    Nampa, ID
    Quote Originally Posted by wannabegtp View Post
    So to get this back on track, this is what I did 4" 22.5* bend:
    Except it is actually attached to the TB, lol
  20. #20 Re: DIY intake
    some guys just put the ait sensor inside the open cone filter and call it good. if the filter is on the TB directly theres no hole to put it in.
    some will just zip tie it to the outside of the air filter. im no fan of either of those.
  1. upper intake and lower intake manifold gasket
    By RICKS04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2014, 12:06 PM
  2. Short Ram Intake, Fender Well Intake, Etc.?
    By Pokealong1227 in forum General Tech Discussion
    Last Post: 05-31-2013, 12:26 PM
  3. Replies: 2
    Last Post: 03-31-2012, 07:49 PM
  4. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
