Thread: E85 no tune
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 67
  1. #1 E85 no tune
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    Hey guys, just bought some 42's and I've read that multiple people go e85 this route and don't tune. I'm not crazy modded, just a 3.4 with headers. It make me a bit weary as to I depend on this car a lot so I wanna make sure I'm safe. How many people here actually do it without a tune?
    Thanks,
    Chris
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  2. #2 Re: E85 no tune
    Jun 2012
    Illinois
    http://www.grandprixforums.net/threa...uestions/page1
    just found this guy all thanks to corey. and it answered my questions. I do have an intense pcm in there. Am i good with that?
    Last edited by chris99gtp; 03-05-2015 at 12:45 AM. Reason: corey actually helped with something
  3. #3 Re: E85 no tune
    Antioch, IL
    2009 Challenger SRT8
    Expert at being gay.
  4. #4 Re: E85 no tune
    Mar 2014
    Tucson
    I did. Everything was cool until my local gas station went above 88%. Many people have done this without a problem. I would HIGHLY recommend buying an e85 tester. That way you know what you're actually putting in your tank.
  5. #5 Re: E85 no tune
    Jun 2012
    Illinois
    I'll look into it. What range should I stay between?
  6. #6 Re: E85 no tune
    Mar 2014
    Tucson
    You should be fine as long as it's between 70% and 85%. That's where it's supposed to be. When mine hit 88%+ my LTFT's were maxing out. I didn't know why til after the fact.
    Do you have a way to monitor fuel trims?
  7. #7 Re: E85 no tune
    when it's not that difficult to actually get tuned for it i don't see the point in doing something with this much potential downside.
  8. #8 Re: E85 no tune
    Feb 2009
    flintnasty MI
    A check engine light might come on.. but even then there is no "downside" to it as it will still be plenty rich enough. This isnt that complicated and the gains you make are significant.
  9. #9 Re: E85 no tune
    you misread.
    i didn't say it doesn't work.
    but it's not that hard to get a tuner strapped to the car to make sure it's CORRECT.
  10. #10 Re: E85 no tune
    Feb 2009
    flintnasty MI
    you misread.
    Its impossible to be wrong unless your fuel pressure is dropping off or something.
  11. #11 Re: E85 no tune
    Mar 2014
    Tucson
    I would say the benefits far outweigh any potential downside. Especially since it's so easy to revert back. Try it. If it doesn't work for some reason, stab your original injectors back in. Shrug.
  12. #12 Re: E85 no tune
    scott, when tuners are damn near free and/or in every other persons hands nowadays you kind of don't have an excuse to not at least check it out for peace of mind. you can't argue that.
  13. #13 Re: E85 no tune
    Arizona
    He'll argue anyway cause he thinks a stock tune should rarely be modified
  14. #14 Re: E85 no tune
    Feb 2009
    flintnasty MI
    You dont need a calculator to make sure 2+2=4
  15. #15 Re: E85 no tune
    lol, these threads.
  16. #16 Re: E85 no tune
    May 2008
    Schuyler, NE
    However, a calculator can be used to double check your answer, which will usually result in greater accuracy.
  17. #17 Re: E85 no tune
    Two things:
    1) You better bring Olds to ICC.
    2) Who uses a calculator? especially when it's just fuel tables that are "apparently" the same?
    Pfffft.
  18. #18 Re: E85 no tune
    May 2008
    Schuyler, NE
    Lol. The olds doesn't run. Or drive. And looks like crap. I have a feeling it will stay like that for a long long time.
    Sometimes I run out of fingers and toes.
  19. #19 Re: E85 no tune
    Jun 2012
    Illinois
    Alright thanks for the input. My plan right now is to switch and then get a tune eventually. I made a feeler thread earlier for people in the Chicago land are who can tune for e85 but no one has responded. I pm'd overkill and he said he wasn't "comfortable not being in the vehicle to tune it". I'm going to keep searching around for people who can tune for it. Anyone have ideas of other people? And my means of "monitoring" is using torque app.
    Chris
  20. #20 Re: E85 no tune
    come up to the racine/kenosha area and a local will tune your car. he's not on here, but if you find the WICGP group on facebook i can point you in his direction.
  1. e85 Dyno Tune at Dyno Tune Motorsports - Video
    By tms8582 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2013, 07:57 AM
  2. tune vs no tune. safe?
    By hollas13 in forum General Grand Prix Discussion
    Last Post: 07-09-2013, 07:54 AM
  3. Need a Tune?
    By NewBoost1997 in forum General Tech Discussion
    Last Post: 03-29-2011, 03:30 PM
  4. need a tune in az!!
    By Joe m in forum Southwest
    Last Post: 11-03-2010, 11:27 AM
  5. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
