Thread: P0300 code , need help !!
Results 1 to 6 of 6
  1. #1 Re: P0300 code , need help !!
    SE Level Member damohr's Avatar
    Mar 2015
    Canada
    ok ill try swapping the coil around tomorrow just to make sure napa didn't sell me a bad one , the contacts where the coil sits on are clean , i cleaned them before putting the new coil on, if that doesn't work ill go to the wrecking yard and pull an ICM , i was also thinking of getting the harness just to make sure its not a broken wire , thank you guys for the input really appreciate it
  1. someone help? p0300 code
    By ericg1181 in forum General Tech Discussion
    Last Post: 04-07-2014, 02:09 PM
  2. Stumped with P0300 code
    By zach101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-20-2011, 04:56 PM
  3. 4-5k rpm misfire, Code P0300.
    By trailshredder in forum Engine
    Last Post: 11-13-2011, 07:43 PM
  4. most common p0300 code fix
    By Wingsfreak9 in forum General Tech Discussion
    Last Post: 09-21-2011, 01:12 PM
  5. Code P0303, and p0300
    By Progas in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2009, 09:08 AM
