Thread: 2006 gxp power steering line blew
Results 1 to 14 of 14
  1. #1 2006 gxp power steering line blew
    Jun 2013
    Canada
    Does anyone know if there are problems with the lines at or around the pump? I was told the return line could blow if the outside temperature is colder than -25 Celsius.
    A little history someone installed new lines but cut them instead of putting in, in one piece. The connected cut ends with rubber hose, which within a week of each other in the cold weather both blew apart. I have replaced both hoses with brass couplings and everything was good for a couple weeks until one morning it was -35 and started the car just to discover that a line near the back of the motor around the pump/rresivoir has blown on me. So here I am without a car again.
    Anything would help.
    Thanks
    Ben
  2. #2 Re: 2006 gxp power steering line blew
    Arizona
    Use AN fittings and some gates hose it's double walled.
  3. #3 Re: 2006 gxp power steering line blew
    Donating Users timboku's Avatar
    Montgomery, IL
    The cold weather issue was a recall. I have had mine replaced 2 times in the last few years..actually the last 2 times I got my trans replaced..lol..anyway not sure if its still an active tsb but call the dealer and ask them. The 2nd time they installed a upgraded hose that was a little.more reinforced iirc.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  4. #4 Re: 2006 gxp power steering line blew
    Arizona
    ^ forgot about the recall might as well hit them up first, itll be alot cheaper
  5. #5 Re: 2006 gxp power steering line blew
    Jun 2013
    Canada
    The thing I found why it blows is the fluid itself.. I had 4L jug unopened in my car overnight at -30 and come morning I opened my trunk to find it had expanded so much that 1/3 of the bottle was on the ground.. they mentioned something about changing the fluid to "cold climate" or something along those lines but will it be good for summer driving also?
  6. #6 Re: 2006 gxp power steering line blew
    Jun 2013
    Canada
    I'm trying to go after go for the power steering and trans cooler but I guess they won't do the cooler because it's considered a mod... they seem to dance around the problem that's for sure. I'll give them a call and let everyone know what comes out of it tomorrow. Thanks for the info
  7. #7 Re: 2006 gxp power steering line blew
    Montgomery, IL
    My trans cooler lines went as well, they didnt cover it. I was already getting a new trans and power steering already so I didnt push the 100bucks it cost. Make sure to get the ignition recall done as well if you havent already while your there.
  8. #8 Re: 2006 gxp power steering line blew
    Jun 2013
    Canada
    So they recalled the trans? What do they do with it?
  9. #9 Re: 2006 gxp power steering line blew
    Montgomery, IL
    Quote Originally Posted by Ben10125 View Post
    No trans was under warranty still.
  10. #10 Re: 2006 gxp power steering line blew
    Bastard Reptile's Avatar
    Kansas City, MO
    If it's -25C, you shouldn't even be out of the house....let alone driving.
    Go hibernate. LOL
  11. #11 Re: 2006 gxp power steering line blew
    Jun 2013
    Canada
    Apparently gm has a recall" they called it customer satisfaction program" for both lines I'm going to be getting a call this morning to see when it can be done.. my gxp has a blown line right now so they are going to have to come get it (tow) and I need a car for daily stuff.. looking forward to see if they will lend me a car until mine is fixed. I'll know everything later today..
    power steering recall is N090132
  12. #12 Re: 2006 gxp power steering line blew
    Montgomery, IL
    Sounds like they are taking care of it for you..that's cool!
  13. #13 Re: 2006 gxp power steering line blew
    Jun 2013
    Canada
    Lol livin in the north buddy.. minus 45 isn't a weird number to see
  14. #14 Re: 2006 gxp power steering line blew
    Jun 2013
    Canada
    I thought so too.. The program expired Feb 28th!! They are talking to their people... I asked them 3 weeks ago about this...
  1. Power steering line routing
    By huttler in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2013, 05:39 PM
  2. Power-Steering Line Replacement
    By quickster in forum General Tech Discussion
    Last Post: 12-09-2012, 09:37 AM
  3. need help!! power steering return line instillation
    By PrixAngel in forum General Tech Discussion
    Last Post: 07-30-2011, 03:24 PM
  4. Power steering line problems NEED HELP
    By supermat690 in forum Introductions/Noob Questions
    Last Post: 10-22-2010, 09:10 PM
  5. Booger I broke Power Steering line
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 10:08 AM
