Thread: cv axel..please help!
Results 1 to 3 of 3
  1. #1 cv axel..please help!
    Mar 2012
    Michigan
    Hello, I have an 01 3.8L pontiac grand prix( not super chared ) was told by a dealership that my cv axel was loose. How hard is it for a grandma to fix it by herself. I'm tired of having to pay mechanics to fix it and have the same problem happen over and over again, it is getting too costly for me.
    Thank you
    Sammie
  2. #2 Re: cv axel..please help!
    Feb 2013
    Missouri
    Not sure what they mean by loose, typically the CV boots will tear, slinging grease everywhere. This tear will also let dirt and debris into the bearings of the CV joint, and that dirt coupled with the lack of lubrication (grease) will eventually cause play in the joint. When there play in the joint, you typically here a clicking sound when you are turning (when the joint is flexed). Do you hear anything when you turn? Turn the steering wheel all the way to the left and look behind the front passenger wheel at the CV shaft for grease and such. Then turn it to the right and do the same for the front driver side.
    This is not my picture, but this is of the passenger side. The CV axle is the bar with the accordions on each end. Those accordions are where they rip, and they'll sling grease everywhere.
    This is not a Grand Prix at all, but it will show you what the tear looks like:
  3. #3 Re: cv axel..please help!
    Oct 2011
    Toledo, OH
    Repeated CV joint failure is probably caused by another problem. Possible motor/trans mounts are SHOT causing bad geometry?
    2005 GTP - Graystone Metallic|SPO grills&spoiler/SE lip/Carbon Fiber INFERNO hood
    7"
    Spectre|3.4 MPS|42lb Blue Giants+E85+Walbro 450lph pump
    SpeedDaddys|AL605|Vogtlands on FE3s|Vinnie's Spacers on solid lowers|Intense poly uppers|
    Dorman + Addco sway bars|Drilled/slotted rotors|Plasti-dip 17" QP2 at +27 offset
  1. Axel: NOMNOM, 4T65E FOR LUNCH
    By AxelRod in forum Members Rides
    Last Post: 11-02-2017, 11:18 AM
  2. CV Boot or New CV Axel
    By TDgrand in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-10-2016, 07:50 AM
  3. Bad axel? help please
    By triebenbach07 in forum General Tech Discussion
    Last Post: 11-17-2011, 11:53 PM
  4. Leaking Trans Fluid (by axel)
    By TDgrand in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-06-2010, 03:20 PM
  5. axel nuts keep coming loose?
    By _nick_ in forum General Tech Discussion
    Last Post: 07-30-2008, 10:36 PM
