Thread: how to replace PS pressure line
Results 1 to 3 of 3
  1. #1 how to replace PS pressure line
    Feb 2015
    Florence Alabama
    I have a 2001 gtp with a pressure line from the power steering leaking I put it on a lift and seen that its gonna be hell my ? Is am I gonna need to drop the cradle down from the body to get the the nut in the back side of the motor and should I replace the return lane while I'm there also
  2. #2 Re: how to replace PS pressure line
    if you lower the rear of the sub frame a few inches you'll have the room, its a 18 mm line nut.
    if its leaking from the nut theres a o ring on line, it maybe bad. some times you can snug it up a bit and it will stop leaking. mt new rack came with new o rings and i never used em. old ones looked good. no leaks.
  3. #3 Re: how to replace PS pressure line
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Return line should last forever, never replaced one before. Unless you damage it messing with other stuff.
  1. Replace Pressure Control Solenoid
    By gates1847 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-17-2020, 01:58 PM
  2. Help with Line pressure setting
    By OrangeL67 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-28-2011, 06:57 PM
  3. A/C low pressure line location on 98 GTP
    By Juanmiguel in forum General Tech Discussion
    Last Post: 02-26-2010, 10:02 PM
  4. Need to replace plastic line and having an issue.
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2009, 04:39 AM
  5. Need to replace plastic line and having an issue.
    Last Post: 02-15-2009, 11:39 PM
