Thread: 2002 heat blows cold air off and on.
Results 1 to 3 of 3
  1. #1 2002 heat blows cold air off and on.
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    In my 2002 with the non electronic dual climate control panel when I have the heat on the driver's side is fine but the passenger side goes from heat then you hear it get louder and switches to cold air and will sometimes go back to heat. Sometimes moving the slider down to cold then back to heat fixes it sometimes not. Vent actuator? Also blower settings 1 and 2 no longer work, I assume that's the blower motor resistor, but figured I'd add it in case the two are related.
    Thanks!
  2. #2 Re: 2002 heat blows cold air off and on.
    Resistor and blender door is acting up.
    Time to get under the dash and see what one is doing it.
  3. #3 Re: 2002 heat blows cold air off and on.
    Feb 2009
    Roanoke, VA
    Is there any easy way to determine which is causing the malfunction?
  1. Cold wind blows
    By Koba23 in forum Introductions/Noob Questions
    Last Post: 12-22-2014, 07:35 PM
  2. Heater blows cold when set to hot and blows hot when set to cold??????
    By Markgp in forum General Grand Prix Discussion
    Last Post: 10-29-2013, 07:38 PM
  3. Max AC blows heat on drivers side only
    By 98GPGT2D in forum General Tech Discussion
    Last Post: 07-07-2012, 08:52 AM
  4. cant control where heat blows to
    By sheffy in forum General Tech Discussion
    Last Post: 01-03-2011, 08:17 PM
  5. My heat only BLOWs on WINDshield?
    By nateberry in forum General Tech Discussion
    Last Post: 02-10-2010, 05:04 PM
