Thread: Testing E85. Do you?
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
  1. #1 Testing E85. Do you?
    Mar 2014
    Tucson
    Just curious if anyone else test their E85? I'm not sure if they change the blends out here for winter or summer, but currently we're running about 88%
  2. #2 Re: Testing E85. Do you?
    i just run it and watch the aeroforce......... lol
    but yeah those kits would be handy for once in a while.
  3. #3 Re: Testing E85. Do you?
    May 2008
    Schuyler, NE
    I don't, but I really need too. It seems to vary a ton here.
  4. #4 Re: Testing E85. Do you?
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    From a tuning perspective I have only noticed winter blend vs summer blend. Just got a tester a few days ago. Only tried it once but it confirms my suspicions that my usual station does do the e70 blend for winter.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  5. #5 Re: Testing E85. Do you?
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    I've been wondering this a lot lately, as I am getting ready to set up my car for e85. Say if it comes out to 75%, would it be recommended to add methanol to a tank to get the mixture right?
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  6. #6 Re: Testing E85. Do you?
    May 2012
    Where winter never ends
    No, just tune it for the season your in. Generally, summer blend says around 85-95% and winter blend stays around 75
    2000 Regal - Winter Beater
  7. #7 Re: Testing E85. Do you?
    Apr 2011
    South Dakota
    Quote Originally Posted by ADecker View Post
    No. Just tune it for right around E80 and never touch it again. Fuel trims handle the rest.
    I love Decker<3
  8. #8 Re: Testing E85. Do you?
    Mar 2014
    Tucson
    See, this is the reason I spent the $18 on the tester. When I first converted, my trims were acceptable. Around +10 on a stock tune. Then one day, out of the blue, my trims jump up to +16 or more. I suspected fuel, but had no way to prove it. Until now.
  9. #9 Re: Testing E85. Do you?
    Apr 2011
    South Dakota
    88% is extremely high for winter blend. In fact its too high for any stock flex fuel vehicle. That station is trying to maximize their margins by blending less gas in (gas is the expensive part)
    I love Decker<3
  10. #10 Re: Testing E85. Do you?
    Mar 2014
    Tucson
    But a higher ethanol content is better for a boosted engine, right? Assuming you can tune for it, or it falls within the limits of your LTFT.
  11. #11 Re: Testing E85. Do you?
    Apr 2011
    South Dakota
    In theory yes. But are hard starts and tune inconsistency worth it?
    I love Decker<3
  12. #12 Re: Testing E85. Do you?
    Mar 2014
    Tucson
    I suppose that would change on person to person basis. If some ethanol is good and more is better, personally, I'll take as much as I can get. Hard starting isn't really an issue here.
    As far as a tune is concerned, wouldn't it be "good enough" to just shoot for the middle of the road? Like you showed in your write up. (See, I did read it! )
  13. #13 Re: Testing E85. Do you?
    Apr 2011
    South Dakota
    Shooting for the middle results in maybe 5% trims in either direction when its e70 to e85. I don't like seeing trims beyond that.
    I love Decker<3
  14. #14 Re: Testing E85. Do you?
    I break stuff selliott's Avatar
    Kansas City
    Where are you guys getting your testers from?
  15. #15 Re: Testing E85. Do you?
    Mar 2014
    Tucson
    Mine came from ebay:
    http://www.ebay.com/itm/Quick-Fuel-E...-/311245826828
    That was the cheapest I found including shipping.
  16. #16 Re: Testing E85. Do you?
    Arizona
    Brandon, I didn't see our usual winter blend either in Arizona for ethanol. Last year was defiantly down to e70.
    I have had a beaker to test out of since I switched to e85. But this year has bee as high as 90% and low as 82
  17. #17 Re: Testing E85. Do you?
    Arizona
    And again this is why I keep saying set the stoich
  18. #18 Re: Testing E85. Do you?
    Mar 2014
    Tucson
    Quote Originally Posted by 91parkave View Post
    I guess so. I'm going to try to play with the tune a little this weekend. I managed to burn all my mixed fuel out of the tank last Saturday. Literally coasted to the pump. Guess my fuel gauge is about an 1/8th off. Oops.
    Anyhow, Pure pump E85 now.
  19. #19 Re: Testing E85. Do you?
    Apr 2011
    South Dakota
    Stoic won't fix blend issues.
    I love Decker<3
  20. #20 Re: Testing E85. Do you?
    Arizona
    But at least it gives your pcm a accurate ballpark target to base fuel calculations from in any circumstance. Just like factory programmed it with 14.7 for gas e85 for 9.87
  1. Testing
    By BillBoost37 in forum Off Topic Discussion
    Last Post: 08-24-2011, 10:21 AM
