Thread: Testing E85. Do you?
Results 21 to 40 of 45
  1. #21 Re: Testing E85. Do you?
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Changing cylinder gain / offset does the same thing.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  2. #22 Re: Testing E85. Do you?
    May 2008
    Schuyler, NE
    It is much easier to do it that way^^ than changing stoich.
    There is a ton of stuff that needs changed in addition to the stoich table if you are choosing that route.
  3. #23 Re: Testing E85. Do you?
    I break stuff selliott's Avatar
    Kansas City
    Quote Originally Posted by BrandonHall10 View Post
    Mine came from ebay:
    http://www.ebay.com/itm/Quick-Fuel-E...-/311245826828
    That was the cheapest I found including shipping.
    Thanks just ordered mine
  4. #24 Re: Testing E85. Do you?
    Donating Users timboku's Avatar
    Montgomery, IL
    Quote Originally Posted by GTPpower View Post
    If going this route, will the wideband still read the same as it would for 93 octane?
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  5. #25 Re: Testing E85. Do you?
    Arizona
    Not really and it's already been proven
  6. #26 Re: Testing E85. Do you?
    Mar 2014
    Tucson
    This may be taking the thread off track a bit, but I think it might be worth it, so her goes;
    Stoich vs. Cylinder gain....
    Iv'e seen a couple times here and there that this method is better than that method, or that way is easier than this way.... As someone who is just beginning tuning, and not really married to one method or another, what I would like to see is factual arguments on why one way is better than the other. Also, where one method falls short compared to the other.
    Why do you believe you method is the "better" way?
  7. #27 Re: Testing E85. Do you?
    Apr 2011
    South Dakota
    Here are my thoughts. http://www.grandprixforums.net/threa...ur-car-for-e85
    To put it simply the cylinder gain method only requires changing one table in the entire tune. If you need to adjust for summer and winter blends it still only requires tweaking the one table. Calling it a table is a stretch even. Its 6 slots that you change from 1 (100%) to 1.25 (125%). Simple and effective.
    I love Decker<3
  8. #28 Re: Testing E85. Do you?
    Arizona
    And I have laid out my explanation as well. And you have the link for 97autovettes writeup. As indicated both methods work. As for my reasoning, well your changing stoich of the fuel so why fudge another table fnot something that never needed adjusting?
  9. #29 Re: Testing E85. Do you?
    May 2008
    Schuyler, NE
    Quote Originally Posted by 91parkave View Post
    I ran e85 for a bit using the stoich option to change it. You need tiny tuner to make all the changes required. Changing cylinder gain, or IFR, you only need to change that one table. Way easier to leave stoich alone.
  10. #30 Re: Testing E85. Do you?
    May 2008
    Schuyler, NE
    Quote Originally Posted by timboku View Post
    You can either run the wideband like on 93 and tune for 11.5 or whatever at WOT, or switch it to e85 and run it at 7.8 or whatever it should be.
  11. #31 Re: Testing E85. Do you?
    Arizona
    cause it was really hard to make some more changes
  12. #32 Re: Testing E85. Do you?
    May 2008
    Schuyler, NE
    It's way easier to just change one, instead of accidentally missing one. If you only have HPT, you don't have an option.
  13. #33 Re: Testing E85. Do you?
    Arizona
    So what happen when you swapped stoich values in the master stoich table what happened? Did your afr go back to 14.7 anyway?
  14. #34 Re: Testing E85. Do you?
    May 2008
    Schuyler, NE
    On a wideband calibrated for gas, yes that's what it would have read in closed loop.
  15. #35 Re: Testing E85. Do you?
    Apr 2011
    South Dakota
    I wish there was a master one like the LS guys have
    I love Decker<3
  16. #36 Re: Testing E85. Do you?
    Apr 2011
    South Dakota
    I think my tune is pretty happy. Running 100% original GM maf table for the 4" truck maf sensor from zzp and 100% correct injector offsets and flow rate. WOT fueling is commanding a static 10.8 commanded afr. Fuel trims are within 5%. Only hacked table is the cylinder gain set to 1.2. Here are the results. Keep in mind this is running winter blend E85 (So actually e70) and a gas calibrated wideband.
    I love Decker<3
  17. #37 Re: Testing E85. Do you?
    Mar 2014
    Tucson
    IIRC, you said you were running 60lb injectors?
    So your IFR table is "60" across the board? No change per manifold vacuum?
  18. #38 Re: Testing E85. Do you?
    Apr 2011
    South Dakota
    Set to 63 across the board. The flow-bench balanced them all out at 63 so thats what I run. Only other fuel system stuff is a AEM 320lph E85 pump. (Im a big fan of using math and logic to tune. Although I have a great talent for educated guessing when I need to. I once modded an entire maf table with only 5 minutes of driving and two wot pulls sent to me in a data log to tune off of. The entire table was within 6% fuel trims when the guy flashed it :P)
    I love Decker<3
  19. #39 Re: Testing E85. Do you?
    Mar 2014
    Tucson
    Okay. I'm running the same pump. No rewire (yet). With 42.5lb injectors.
  20. #40 Re: Testing E85. Do you?
    Arizona
    If you're running a return style system than regardless fu El should be flat across the ifr table. Return less style are gls generally a upward slope.as stated above
  1. Testing
    By BillBoost37 in forum Off Topic Discussion
    Last Post: 08-24-2011, 10:21 AM
