BillBoost37, I located the transmission housing bolt that is most front. To verify, just to the right of this front bolt (about 2 inches or so) there are 2 transmission fluid lines that are routed.
This trans bolt is located above the engine starter.
On this trans bolt, I see a black wire (I believe that is the ground wire from the battery) connected to this bolt, and also 2 smaller wires.
All these wire are intact. There are not bad in any way. I have never done any work in that area.
It is also dry in the area around that trans bolt. The rest of the trans is damp from engine coolant from the LIM gasket leak.
Just in case there is corrosion on this trans bolt with the wires that I cannot see, do you think it is worth removing the bolt?
I will be driving the car in next 15 minutes. I will report back if the random electric issues continue.
