Hey gurus, if there are any of you out there, lol.
I swapped in a CS144 into my 2000 GTP and all has been well for the most part. This tax season I replaced it and upgraded the replacement to a 200amp kit I picked up from Alternatorparts.com . The kit included a stator, rectifier, and new brushes. Everything went easy and it worked great, with one heated seat on, the stereo on (not too loud though), and the blow motor on it maxed out Orielly's tester at 99A at idle. The battery did test bad though, so I warranteed that out, so that's new, too. We got a pretty good snow storm so the car sat for a few days, but I remote started it to let it idle and warm up for 15 minutes. I finally got out of the driveway yesterday and made it to work. On the way home I noticed my lights dim really bad with the slightest load (fog lights, blower motor, small things). I figured it was just cold and waited til today to check it out. Same result. I took it down to oriellys and had them check it again and with nothing on but the engine it tested 52 amps...right about stock. I checked the voltage and in park, with nothing on at all I'm at 14.18v, turn the blower motor on low and it drops to 13.5v. Turn the headlights on, heated seat, etc. (simulating my drive home last night) and I was sitting at battery voltage.
I've been calling the guy at alternatorparts.com who is a really cool guy when he answers the phone... I was wondering if you guys have any idea what it could be...rectifier? Voltage regualtor? Belt is good and tight, and relatively new. Would a voltage regulator cause this?
